Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-03-2022, 09:14 PM   #1
lewesyru
Drives: 2022 Subaru BRZ Limited
Lightbulb New member introduction & TPMS self-service findings
Hi guys! Lewes here.
I'm located in MA, and I was so lucky that I got my '22 BRZ Limited a month ago in MSRP from a local Subaru dealer. I have actually been browsing around as a guest for a few months now. I finally registered an account and I have something would like to share with everyone. But first, here is the beauty
As you can see, I put a new set of wheels and tires on it.
It's 18x8 Sparco Podio & 225/40ZR18 Continental ExtremeContact DWS 06 Plus.
I ordered the tire&wheel package on Tire Rack, it came in with their T6 TPMS sensor. I'm so in love with these fainted bronze-ish color pair with the metallic grey.
Now here is the thing, since I got new tire&wheels, so it came the 2nd set TPMS issue. I've been browsing around for a solution, and I've found that Panda Grahams was able to register with Autel TS501 in this thread: https://www.ft86club.com/forums/show...1&postcount=17. So, I bought the same model on Amazon, trying to do that myself.
A few days later I got the TPMS tool, update the software to the latest. Well, unfortunately, the latest version of TS501 firmware still does not support '22 BRZ/GR86. I tried using the gen1 option but with no luck.
Not responding
I was thinking that maybe the unit I got is broken. So I decided to take a test on my roommate's '14 Toyota Camry before I return it. Then, I found that there are 2 options for '14 Camry.
I tried both 2 & 3, only option 2 works. But both of them are 315MHz. So first, the device is good; second, other than the frequency, there must be something else that stopped the device to detect the sensors on my BRZ. azndavepgh also noticed the same issue in this post: https://www.ft86club.com/forums/show...31&postcount=4
Enough story, HERE IS THE IMPORTANT PART: (and solution)
I was somehow randomly chose the option 1: 01/2020 - 12/2021 (Snap-in 315MHz) for Camry, and forgot to turn the device off. And I walked by my BRZ, it start beeping!! IT FREAKING WORKED!!
UPDATE: The ID is my rear left tire and I was using the front left option to start the sensor detecting. This is only for demonstrating that the Camry setting will work with '22 BRZ. Sorry for some confusion here and thanks MikeNSX2 for pointing it out!
I also tried on OEM sensor, it also worked. So, both Tire Rack T6 & OEM will work under the Camry setting. So I think we can say this new sensor is definitely from Toyota.
Then I connected the OBD2 cable, trying to read the sensor ID under Camry setting, it also worked.
So then I followed the sensor relearn guide from Autel, I completed the relearn procedure without trouble. I'm not going into too many details here, since you can find a lot of guides online. When it finally going to write the new sensor IDs in, it asked me if I wanted to save as a 2nd set. I selected yes.
Then I read the id from ECU again to make sure it wrote something in. I got the same OEM IDs, but there are '(1st)' after the IDs (forgot to take a photo for this one). I tried triple press the TPMS button, the warning light flashed a few times and then disappeared. Then I read the ECU again, and check this:
The second set has a '(2nd)' after their IDs. They've been written in.
After the relearn was completed, I drove only ~2 miles, it shows up correctly in the dash.
And I just canceled the dealership appointment and saved a few bucks! (yeah but spent 200+ bucks on the tool lol)
I noticed that some people found that the triple press TMPS button doesn't work. https://www.ft86club.com/forums/show...6&postcount=23
It is because if the 2nd set isn't present, the triple press will do nothing at all. You have to register the second set to make the switch function work.
I assume that other brands of TMPS tools might also work, too. As long as it has OBD relearn function. Can anyone try on another brand?
Finally, hope the TPMS part can help some people out. Thanks!
lewesyru is offline   Reply With Quote
The Following 21 Users Say Thank You to lewesyru For This Useful Post:
Aroundomaha (02-14-2022), azndavepgh (02-04-2022), bcj (02-04-2022), Busybee (02-08-2022), Cephas (03-10-2022), cpierr03 (02-03-2022), DocWalt (02-04-2022), dsc_pat (02-04-2022), eyeballs (02-03-2022), Falken86 (02-04-2022), joemysterio (02-04-2022), MikeNSX2 (02-04-2022), MMoore4545 (02-04-2022), Ohio Enthusiast (02-08-2022), Panda Grahams (02-03-2022), Pete (02-03-2022), soundman98 (02-04-2022), Stonehorsw (02-03-2022), T-Steve (02-03-2022), timurrrr (02-03-2022), Up4speed (02-04-2022)
Old 02-03-2022, 09:30 PM   #2
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Great luck finding this accidentally! And thanks for sharing.
This should probably also work if you choose some other Toyota model that uses the same sensors:
Originally Posted by azndavepgh View Post
It looks like the new sensor is a Toyota part used on the Avalon and probably others.
timurrrr is offline   Reply With Quote
Old 02-03-2022, 09:40 PM   #3
lewesyru
Yeah I think other model options should also work without problem. I haven't tried that though
Old 02-03-2022, 10:24 PM   #4
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Did the Canadian Sport-Tech version not come with TPMS? I can't say I've ever found a menu that showed me tire pressures. Also since changing to winter wheels without TPMS I haven't seen any dummy lights on the cluster. Im very confused how I don't have TPMS if I bought the upper Sport-Tech model.
Midnightsky is offline   Reply With Quote
Old 02-03-2022, 10:41 PM   #5
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Good to know!! I'm going to give this a shot.
Edit: Mine worked to clear the TPMS warning light, but I was never able to pull pressures and the light did eventually return. But I'll give the Camry setting a try. Thanks!
Panda Grahams is offline   Reply With Quote
Old 02-03-2022, 10:43 PM   #6
jvincent
jvincent's Avatar
Apparently Subaru doesn't put TPMS into their cars in Canada. Found that out when I went to put winter tires onto the OEM rims.
Old 02-03-2022, 10:55 PM   #7
Midnightsky
Very strange choice by Subaru Canada. Do we have access to it if we buy some?
Old 02-03-2022, 11:05 PM   #8
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
It's because they don't have to. Americans rolling Ford Explorers on Firestone tires is what created TPMS... just like the runaway Lexus caused the floor mat tie down and that poor woman who spilled hot coffee in her lap gave us standard cup holders.
2020BRZtS is offline   Reply With Quote
The Following 3 Users Say Thank You to 2020BRZtS For This Useful Post:
soundman98 (02-04-2022), Ultramaroon (02-04-2022), Xed32 (02-11-2022)
Old 02-04-2022, 09:42 AM   #9
jvincent
jvincent's Avatar
Given that it doesn't show up in any of the menu systems if might need to be enabled by the dealer or require a different S/W variant for the control system.
Personally I'm happy to not have the persistent warning light that I had on my FRS.
Old 02-04-2022, 11:39 AM   #10
azndavepgh
Drives: 2022 BRZ
Great write-up!
azndavepgh is offline   Reply With Quote
Old 02-08-2022, 06:44 AM   #11
emce
emce's Avatar
Drives: 22 BRZ Limited
Probably a stupid question, but how did you write back to the ECU after you scanned the new sensors? I have the same tool and I've gotten as far as it reading the new sensors just fine, but when I'm trying to use the Relearn option it gives me a bunch of instructions where one step says, "write the new sensors to the ECU" and I can't figure out how to do that
The online guides imply it should just pop up a write option when I connect it to the vehicle via OBD, but that doesn't seem to be happening.
EDIT: Nevermind - repeated the whole procedure again and this time it successfully wrote them.
emce is offline   Reply With Quote
Old 02-08-2022, 09:11 AM   #12
MikeNSX2
Drives: Ice Silver 2022 BRZ Limited
lewesyru,
Thanks for the great write-up.
A question though...
In your first picture, it shows the front left tire ID as 4DEA9CB
In the second picture, it shows the front left tire ID as 5304B6C.
In the third picture, it shows the front left tire ID as 424A023.
I'm going to Discount Tire tomorrow to have them read the sensor IDs (which I will write down) and then go to my my Subaru dealer and have them register them to my car.
How will I know which tire sensor ID #s are correct for my BRZ? Yours were all different.
MikeNSX2 is offline   Reply With Quote
Old 02-08-2022, 11:59 AM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Each sensor has a unique ID. It should also be written on the sensor.
Old 02-08-2022, 12:34 PM   #14
MikeNSX2
I understand that each sensor has a unique ID.
That said, in his three pictures, all of which show the front left tire sensor ID number, well... they are three different numbers showing as the front left sensor ID.
new member, tpms
Introduction/new member Desertnate BRZ Second-Gen (2022+) — General Topics 2 02-01-2022 08:43 AM
R&D Findings on Crank Case Ventilation falcon_wizard Engine, Exhaust, Transmission 18 04-18-2021 12:33 PM
Interesting Findings after ProECU Tuning! vagthomas Software Tuning 11 12-06-2017 03:24 PM
AZP Aug/Sep Discounts on Major Service & TPMS Cloning! AZP Installs NY / NJ / CT / PA 0 08-17-2014 09:53 PM
Interesting Findings about BRZ Audio Output Chad_W Electronics | Audio | NAV | Infotainment 14 05-03-2013 08:28 PM
