Old 02-02-2022, 12:40 PM   #1
Kūsho
Drives: 2018 50th Anniversary BRZ
Exhaust Options
New BRZ owner seeking exhaust advice for future upgrades.
I'm looking at the nameless axelback exhaust currently. Looking for a nice subie rumble that isn't too loud, so the 5" muffler option sounds nice. However, I've been informed that since I want to turbo it eventually, i shouldn't have mufflers over 3.5". So, my question is: do I go with the Nameless "delete", have a custom made exhaust that is relatively close, if not directly modified nameless, or look at a different exhaust entirely?
I also am looking at Tomei catless headers aswell
Thank you to all that respond
Kūsho is offline   Reply With Quote
Old 02-02-2022, 02:03 PM   #2
Poogchomp
Poogchomp's Avatar
Drives: Chevrolet Ram 250
Don't do cables headers and muffler delete unless you want your car to be incredibly loud. My suggestion is to go on YouTube and find sound clips of cars with uel headers and various cat backs to find one you like. I wouldn't buy headers unless you plan on reselling them or use a kit that let's you use them.
I got a smooth brain.
Poogchomp is offline   Reply With Quote
Old 02-02-2022, 04:01 PM   #3
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Try going through the build pages/car journals to see what works for FI cars.
Do as much "research" as you can on exhausts and their compatibility for certain kits. You can start with the axleback first or even a catback and see where you would go from there. Your vision of your car may change with the more you learn.
Some kits even use the stock manifold or even a different one from what you're already looking into.
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
Old 02-02-2022, 04:21 PM   #4
Grady
Grady's Avatar
Depends on the rest of your exhaust. Here is my exhaust journey. First was dual cat gut and stock exhaust. It was loud but not too for my taste, no drone. 2nd step was AVO turbo this was too quiet. I did a cut and re weld on the exhaust to eliminate mufflers. Back to loud but not bad, no drone. Next step was full 3 nameless no mufflers. This was great for the track but too loud for the street, lots of drone. Next step was 3 inch muffler names axle back. This was good on the street but wanted more for the track, no drone. Since I had 2 nameless axle backs I cut one of the mufflers out and put one of the pipes from the muffler less on with an exhaust valve. Now the best of both worlds. 1, don’t piss of the neighborhood at 5AM when I am goring to work and when open it is perfect for the track or afternoon drive.
Old 02-02-2022, 08:31 PM   #5
PenGun
Drives: Red 2019 Subaru BRZ
Yeah, the car sounds pretty good stock.
I spend my sound money on my stereo. Its actually worth almost what my car is now, and I have a record player I will put up against any DAC on the planet.
PenGun is offline   Reply With Quote
Old 02-02-2022, 11:13 PM   #6
macuser27
macuser27's Avatar
I like my
macuser27 is offline   Reply With Quote
Old 02-02-2022, 11:41 PM   #7
jflogerzi
jflogerzi's Avatar
Do not do Nameless + Tomei. I had this setup before and it was pretty damn loud and was tiring on longer drives. Start with your headers first and work your way back. Catless headers add alot of noise. Honestly if your going turbo, why waste money on headers your going to need to sell/replace. Without a tune headers are useless and just make more noise.
2013 Series 10 FRS #553
exhaust, nameless, nameless performance
Cat Back Exhaust with Resonator Options? cslntuee Engine, Exhaust, Transmission 8 08-17-2014 09:48 PM
Aftermarket Exhaust Options Moe AFRICA 49 03-03-2014 04:03 PM
Exhaust tip options (NOT JDM/TRD)? FR-Slide Cosmetic Modification (Interior/Exterior/Lighting) 11 02-26-2014 08:27 PM
FI Exhaust Options ecko04 Forced Induction 28 08-12-2013 01:41 PM
Exhaust options for 13' FR-S? Gwest11 Engine, Exhaust, Transmission 8 05-31-2013 07:31 AM
