Old 01-13-2022, 09:43 AM   #1
Ninimodz
Drives: White 2013 brz
Vacuum leak? 2013 Brz
Hey guys, I'm new to the forum and new to cars. I purchased a 2013 Brz with the intent to learn more about cars and work on it. It's been a golden car, runs great but after some time I noticed some weird things that I think all revolve around the same issue. It has some work done to it, turbo, fuel pump etc. I can provide all upon request. The symptoms, at first I noticed (usually after a pull) would be a weird smell, like something burning? Then I got a check engine light (also traction control light turned on) with the code p0441 Evap Emission System Incorrect Purge flow. The guy I bought it from said it was because of the tune (ecutek) and it can't be tuned out. Then I noticed upon starting the car, the RPM's change from about 1500 down to 750ish then idles at about 1k. When reversing, I've stalled out once or twice (and almost stalled out a lot) with the clutch pushed in. I assume it's some kind of vacuum leak, but I don't know where to start looking for it. I am new to working and learning about cars and mods so don't yell at me. Any ideas?
Ninimodz is offline   Reply With Quote
The Following User Says Thank You to Ninimodz For This Useful Post:
humfrz (01-15-2022)
Old 01-15-2022, 05:29 PM   #2
stacyu18
Drives: 2014 subaru brz
under the intake its a common leak just a starting point
stacyu18 is offline   Reply With Quote
Old 01-15-2022, 08:01 PM   #3
humfrz
I suggest you take it to a tuner and ask him to straighten it up.
Save your yearning to work on cars for a simpler project -
Vacuum Leak? Jerks when losing speed. Jayy32 Scion FR-S / Toyota 86 GT86 General Forum 2 07-21-2021 09:31 PM
Is this a sign of a vacuum leak? kev0 Issues | Warranty | Recalls / TSB 8 10-29-2019 10:24 AM
Does this sound like a vacuum leak or bad A/F sensor? kev0 Issues | Warranty | Recalls / TSB 1 08-26-2019 06:03 AM
Exhaust or Vacuum Leak when Hot kchar Issues | Warranty | Recalls / TSB 3 11-22-2015 12:17 AM
Vacuum Leak?? woode Forced Induction 31 05-25-2014 05:09 AM
