Old 08-25-2019, 10:23 AM   #1
kev0
Drives: '14
Does this sound like a vacuum leak or bad A/F sensor?
P0171 code, running lean, o2 Sensor shows incomplete in OBD2 monitor report.
Could my catless UEL Header be causing the o2 sensor to show as incomplete? I’ve passed emissions with it before and the sheet showed that it was ready last time I did emissions. Could it be possible that my AF sensor has just gone bad?
kev0 is offline   Reply With Quote
Old 08-26-2019, 06:03 AM   #2
Boccaccio
CAD monkey
Boccaccio's Avatar
Drives: '15 GT86 Giallo - Supercharged
Hey, Kev
Check the resistance of the A/F sensor:
https://demos.starbase7.net/t3Portal..._rm_index.html
Engine/Hybrid System -> FA20 Engine Control -> Air Fuel Ratio Sensor -> Inspection
I've recently fixed my friend's car with similiar problems. On top of the P0171 code, there were also the P117B and P0172 faults.
Replacing the A/F sensor with a new Denso unit and a "stock" the drop-in filter (DO NOT install the MANN C2620 OE replacement filter) fixed the problem.
The car is driven with an appropriate tune (catless exhaust manifold)? Presence of exhaust leaks has been checked (Manifold - Engine Block and Manifold - Overpipe + both sensors, A/F and heated oxygen)?
Boccaccio is offline   Reply With Quote
Possible vacuum leak? (Running lean and high fuel trims) nickw14 Engine, Exhaust, Transmission 6 02-10-2023 11:56 AM
Is this a sign of a vacuum leak? kev0 Issues | Warranty | Recalls / TSB 8 10-29-2019 10:24 AM
DIY - Finding a vacuum leak (Cigar/Pump method) BigTuna DIY (Do-It-Yourself) Guides 0 08-12-2019 11:13 AM
Exhaust or Vacuum Leak when Hot kchar Issues | Warranty | Recalls / TSB 3 11-22-2015 12:17 AM
Vacuum Leak?? woode Forced Induction 31 05-25-2014 05:09 AM
