Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 01-13-2022, 05:46 AM   #1
andrew4554
Drives: 2015 Scion FRS
Shifter
Supposedly the new GR86/BRZ has a better shifter then the gen1.
Less "notchy" and better cross shifting action.
Are they interchangeable with the gen1. Thoughts?
andrew4554 is offline   Reply With Quote
Old 01-13-2022, 07:13 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The upgrade in the shifting action is likely done in the transmission. I would guess that the shifter itself has the same measurements as the old one, but is different because they redesigned the reverse lockout mechanism.
dragoontwo is offline   Reply With Quote
Old 03-14-2022, 08:38 AM   #3
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
I found the shifter to be incredibly stiff and notchy when changing gears in a dealer's showroom demonstrator, to the point of being a deal-killer. So a question for owners: Does it feel considerably more fluid and easier to shift once the car is running? There's no opportunity to test drive one around here to find out for myself.
Sport-Tech is offline   Reply With Quote
Old 03-16-2022, 04:14 AM   #4
Mo*86
Mo*86's Avatar
Drives: GT86 2014-2020
Do you consider that the engine is not running and the synchronization does not work properly and the transmission oil is also cold?
Mo*86 is offline   Reply With Quote
Old 03-16-2022, 07:15 AM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Shifter feels very similar to the old car, if anything it’s easier to shift.
Old 03-16-2022, 01:51 PM   #6
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
I'd wager that's a bad sample. It shifts like the first gen. I put in Motul gear 300 75w90 oil and feels better (less abrasion) in the lower gears. There's still the off notch here and there but overall it's a decent gearbox and shift action.
Re_Invention is offline   Reply With Quote
Old 03-16-2022, 04:54 PM   #7
jvincent
jvincent's Avatar
IMO the shifter is improved compared to the first gen.
Generally more crisp shifting and no more issues getting into 2nd that the original had occaisionally.
Old 03-16-2022, 06:37 PM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Some of the best shifters can feel horrible when the car is stationary and cold.
timurrrr is offline   Reply With Quote
Old 03-16-2022, 09:22 PM   #9
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Well my car is a manual and there isn't that much difference in effort and smoothness on/off, hot/cold, hence the question.
Old 03-17-2022, 03:26 AM   #10
jimmyjazz86
Drives: 22’ Red GR86 MT Premium
I haven't really driven any other manual cars (just an older Golf and my buddy's VA STi), and it feels snappy and responsive to me compared to those. I have also noticed, that as I've worn it in in the last ~400 or so miles, there is a little less "crunchiness" in the gears, particularly 1st and 2nd.
jimmyjazz86 is offline   Reply With Quote
Old 03-20-2022, 12:01 AM   #11
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Too bad the salesman couldn't have told him that !!
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
Shifter springs/bushings/shifter performance Darnold Engine, Exhaust, Transmission 10 10-22-2014 11:49 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
