Drives: 2017 Brz
pulsing dash and headlights
Hello, so i installed the trackbox from geralds projects on my car, it just plugs into a connecter for the canbus so i wouldnt think it could really short anything out. i did remove the accessory connector for the steering wheel and replug it aswell in this time. Car gets power but wont go into accessory mode or even attempt to start. Not sure where to Start with trouble shooting this? anyone got any suggestions, Thanks.
ProCrastinationConsultant
first step is to check fuses, under the hood, and under the dash, drivers-side floor board.
Then, after you check all the fuses, I suggest you return your system to the way it was before you started your modifications and see it runs proper.
Drives: 86 GT
Pulsing lights when accessory is on typically means the battery has a low charge.
DIY stuff at Compelica Works
#5 | |
Or regulator. The first step is to check voltage at the battery though.
| FR-S Pulsing Under Acceleration | SuperFR-S | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 11-15-2021 06:06 PM |
| 2015 FRS pulsing at low RPM's in 1st gear | ImBatman | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 06-07-2019 11:48 AM |
| Question about dash icons and headlights/fogs/highbeams | TooSlow | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 06-28-2018 03:27 AM |
| Pulsing when Accelerating | carma143 | Issues | Warranty | Recalls / TSB | 41 | 02-27-2015 08:29 PM |
| weird pulsing while stopped | neil125 | Issues | Warranty | Recalls / TSB | 2 | 05-14-2013 11:04 PM |
