Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 01-08-2022, 01:30 PM   #1
racingfool
racingfool's Avatar
Drives: Miata
steering knuckles
I prefer the looks of the GR but I want the aluminum knuckles from the BRZ.
Are they interchangeable? Geometry the same?
Any thoughts as to why the difference?
racingfool is offline   Reply With Quote
Old 01-08-2022, 01:58 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I believe Savage Geese said they are the same and are easily swappable if you're so inclined.
MS, CSCS, TSAC-F, CPT
Old 01-08-2022, 02:37 PM   #3
raisingAnarchy
Drives: '20 Tundra, '84 SpecE30
Only $340 each from Subaru! lol
https://parts.subaru.com/p/Subaru_20...8311CC010.html
raisingAnarchy is offline   Reply With Quote
Old 01-08-2022, 03:05 PM   #4
PLF69
Drives: 2020 M340i, 2022 BRZ
What's the final verdict on this ?
Did Toyota use the steel ones to save cost or because they are stiffer than the aluminum ones (may give better steering feel)
PLF69 is offline   Reply With Quote
Old 01-08-2022, 04:56 PM   #5
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I believe Toyota SAYS they are stiffer, and my guess it is technically a true statement. But is a person actual going to notice a difference in stiffness of the knuckle considering you've got rubber bushings, tires, and coil springs all moving about? Hell no.
Some possibility not considered is that Subaru and Toyota started with some baseline and then it was Subaru that decided to make aluminum knuckles independent of Toyotas engineering team.
Old 01-08-2022, 06:54 PM   #6
PulsarBeeerz
Drives: JRSC BRZ SOLD
They will lessen the un-sprung weight as well. I assume there are published weights somewhere of each.
PulsarBeeerz is offline   Reply With Quote
Old 01-08-2022, 08:30 PM   #7
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Be aware that the aluminum knuckles are not compatible with some BBKs on the market.
Otherwise should swap fine.
Minimal weight savings, probably not noticable.
A lightweight battery is probably better value for money.
timurrrr is offline   Reply With Quote
Old 01-09-2022, 12:29 AM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
A quick search reveals this:
Originally Posted by Opie View Post
2013-2020 Steel knuckles: 12.41lbs each
2022 Aluminum Knuckles: 9.08lbs each
3.33 lbs less each (6.66 lbs net weight less)
Old 01-09-2022, 12:31 AM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
https://minkara.carview.co.jp/smart/...4954/note.aspx
Old 01-09-2022, 04:09 AM   #10
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Some possibility not considered is that Subaru and Toyota started with some baseline and then it was Subaru that decided to make aluminium knuckles independent of Toyotas engineering team.
According to reports of Toyotas 3 month tuning delay, these knuckles were changed to the old ones at the very last minute.
There is a chance it was done to improve the balance of the car at the limit, Toyota was (again according to reports at the time) really struggling with some of the tuning.
Blighty is offline   Reply With Quote
Old 01-09-2022, 04:19 AM   #11
Blighty
I'd wait for someone to check it out.
Its probably cheaper to just get the GR86 front facia for your BRZ.
Old 01-09-2022, 10:31 AM   #12
PLF69
Interesting, if we keep in mind the front damper tuning is not the same, it could be that the heavier stiffer kuckles were a better match for what they wanted to achieve.
I don't mind it at all they will probably do some additional tuning and changes as the year go on.
Old 01-09-2022, 10:45 AM   #13
PBR
PBR's Avatar
Drives: 2022 BRZ Limited 6 speed manual
It's a cheaper part and more durable. Most likely nothing to do with any kind of performance. Aluminum provides better NVH as well as less unsprung weight. But balance and feel? That sounds like a marketing department not an engineer.
PBR is offline   Reply With Quote
Old 01-09-2022, 07:12 PM   #14
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Cast iron is stiffer. Would you notice? I don't know, would you notice the rear swaybar being mounted to the subframe versus the body? Would you notice the difference between a 18.3mm hollow swaybar versus a 18mm solid one? Would you notice putting the 18mm bar bushings on the 18.3mm bar to get more squish in the rubber and more stiffness?
The aluminium knuckles by themselves are probably not better or worse, they probably don't make that huge of a difference in the overall setup.
I'd spend my money elsewhere on things that would make more of a difference.
Drop Knuckles instead of lowering Springs or Coilovers FRSPacNW DIY (Do-It-Yourself) Guides 19 10-09-2017 12:42 AM
PBM modded knuckles sid94 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 07-12-2017 05:40 PM
Wisefab knuckles Ryaquinn Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-27-2014 12:28 AM
