Old 01-06-2022, 08:07 PM   #1
rylowe626
Drives: Turbo Toyota 86 GTS White
2012 86 Steering abnormality
Hi guys, ive owned my 86 for about 5 years now and for the last few months its been driving in a very unusual mannor.
When i make a right hand turn at speed, once the car loads up into the corner, i hold the steering wheel steady but car rotates more agressively. As if i had addded steering angle. I can feel something sort of pop over into this differnt position.
When i straigten out the wheel is down to the left about 1/8th of a turn.
After some distance or any movement to the left the steering "pops" back into place and the wheel is straight ahead again
Going around a left turn has no issues what so ever
Its got new coil overs, new steering rack, new rear subframe bushings. The alignment and tyres are good (i work in a shop with all the alignment gear)
Running 18x9.5 +38 with 235/40/18 pilot sport 4
None of the bushings are torn/damaged and i cannot get any excess play out of anything. Myself and 2 other mechanics have spent well over 10 hours under this thing and cant figure it out.
Might be something dumb or something unusual so i figured id make a forum post and see what the collective wisdom of the community gets me.
Thanks guys
(1st post)
rylowe626 is offline   Reply With Quote
Old 01-06-2022, 08:14 PM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
Very possibly a front ball joint. Check again. I had almost the exact same symptoms. Turned out to be a lower ball joint.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 01-07-2022, 08:03 PM   #3
rylowe626
Lower ball joint on the front hubs?
Old 01-11-2022, 04:20 AM   #4
Purist
Purist's Avatar
Drives: Subaru BRZ
I'd put money on it. Maybe even the bush where the arm bolts onto the chassis (not sure of the technical term).
Less More
issue, suspention, turning
2012-2016 JDM Steering Wheel blazephantom Interior Parts (Incl. Lighting) 0 05-19-2021 10:17 AM
2012 BRZ starts, but steering lock doesn't release (amongst other things) HazardousWaster Issues | Warranty | Recalls / TSB 2 12-25-2018 06:12 AM
Recall on 04/2012-03/2015 86's for faulty power steering mechanism shodan AUSTRALIA 9 05-14-2017 11:48 PM
Paint abnormality! FR-anco89 Issues | Warranty | Recalls / TSB 2 04-16-2013 09:48 PM
Scion FR-S FIRST DRIVE - Dallas (Grand Prairie, TX) (Aug 4, 2012 - Aug 5, 2012) Xdragonxb0i Scion FR-S / Toyota 86 GT86 General Forum 0 06-30-2012 12:37 AM
