Old 01-03-2022, 08:01 AM   #1
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Tire Fitment for 17x8 +35
Trying to get ready for new tires. They are currently sitting on the stock tires and are a little stretched. Im trying to get a better tire fitment.
AVID1 AV20
17x8
Offset +35
Backspacing 5.88
Hub Bore 73.10
5X100
Old 01-03-2022, 08:18 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
225's
The Following User Says Thank You to x808drifter For This Useful Post:
spcmafia (01-03-2022)
Old 01-03-2022, 08:25 AM   #3
spcmafia
spcmafia's Avatar
Originally Posted by x808drifter View Post
225's
Same aspect as OEM?
Old 01-03-2022, 08:58 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
225/45R17 is pretty ideal.
I run those on my 17x8 +38.
I've seen friends run a 245/40R17 on a 8".
There are some threads on here about 245 tires becoming pinched on 8" wheels. Can effect feel.
235/40R17 probably has about perfect width for the wheel, but overall diameter will be less than stock setup. Availability also sucks when I looked at that option.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 01-03-2022, 08:59 AM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Same aspect as OEM?
Yes. 225/45-17
Old 01-03-2022, 09:08 AM   #6
spcmafia
spcmafia's Avatar
Originally Posted by ZDan View Post
Yes. 225/45-17
Sweet. Thanks! Im going with Pilot Sports A/S 4 since there's a pretty good deal at Costco.
Old 01-03-2022, 12:02 PM   #7
Tatsu333
Drives: 2020 BRZ Sport Tech RS
As others have said, 225/45R17 is a perfect fitment on a 17x8 ET35. It's what I'm running.
The Michelin's are a great choice for an all-season, and they have a squarer shoulder profile than the Pirelli's I'm currently running, making them look a little beefier and fill out the fenders a bit more. I'll be switching back to Michelin's after this set is ready to retire. That said, there's PLENTY of selection available in that size.
You can also go 245/40R17, but that's on the (low end) limit for wheel width for that tire width, and there's a much slimmer selection of tires available in that size. From what I gather, there *shouldn't* be any rubbing unless you're running a lot of camber from camber bolts. If you're on coilovers, then no issues.
Tatsu333 is offline   Reply With Quote
The Following User Says Thank You to Tatsu333 For This Useful Post:
Best tire fitment 18 x 9.5 +35 golemslord Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-15-2020 11:01 AM
Need help on tire fitment white_frs_e46 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-03-2015 07:25 PM
Rim and Tire fitment XXR 530 zuurdeegfrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-19-2015 10:17 PM
AP Racing Sprint fitment on XXR530 17x8.25 ET25 dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-09-2015 04:52 PM
FS/FT: 17x8 +35 5x100 RPF 1 FR-S/BR-Z Fitment Storm Trooper Wheels and Tires 1 04-11-2014 01:57 PM
