Old 12-27-2021, 08:09 AM   #1
grumpysnapper
grumpysnapper's Avatar
Sick of replacing RH drive shaft seals...
I'm a constant victim of my own laziness... 3 seals in 4 months.
Finally took the time to put on some heat protection where the exhaust passes the diff and cooks the seal until it lets go in a dramatic haze of white smoke.
grumpysnapper is offline   Reply With Quote
Old 12-27-2021, 08:19 AM   #2
Ashikabi
Ashikabi's Avatar
You're the first one I've seen with this issue... Are you certain you are installing the seal correctly? Is the shaft that passes through it damaged?
Old 12-27-2021, 08:38 AM   #3
grumpysnapper
Yeah, drive shaft (800HP Level 4) is perfect and was checked (again) recently when I had the diff and OSGiken LSD serviced.
Diff guy said it was definately the exhaust overheating the seal area, and all three occasions it happended at the same time of day on one of the rally "track days"... almost exactly at the same time my engine temps get ugly too.
The motor does now generate some serious heat in to the exhaust (on those dirt track days), which is a larger diameter , and I had specially made to tuck into the bottom of the car as close as possible... so it runs quite tight to the diff housing.
Old 12-27-2021, 08:56 AM   #4
Ashikabi
Ashikabi's Avatar
Oh you have a custom exhaust, that's why I haven't heard anyone complain about it yet. I'll have to keep an eye out then as my pipes are pretty close to the diff too. Maybe you should be running a diff cooler like the drift guys
The Following User Says Thank You to Ashikabi For This Useful Post:
soundman98 (12-27-2021)
Old 12-27-2021, 09:06 AM   #5
grumpysnapper
Thats my next step if I keep having issues, but if i can fix it with some simple insulating, then I'll be happy.
The Following User Says Thank You to grumpysnapper For This Useful Post:
Old 12-27-2021, 09:12 AM   #6
Ashikabi
Ashikabi's Avatar
Agreed
Old 12-27-2021, 10:10 AM   #7
gpvecchi
gpvecchi's Avatar
I fitted Cusco protection to mine.
gpvecchi is offline   Reply With Quote
Old 12-27-2021, 11:55 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think you would have been better off doing a full wrap.
A lot of us have issues cooking the grease in the left CV axle on the diff side. I dunno if that is worse or better then your issue
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
grumpysnapper (12-28-2021), soundman98 (12-27-2021)
Old 12-28-2021, 05:53 AM   #9
grumpysnapper
I decided against the full wrap back there, because the bottom of the exhaust gets peppered with rocks and mud...so will just end up being destroyed.
My issue is really just the radiant heat directly above the custom pipe into the diff seal area, the clearance between pipe and housing is probably only 5mm. (my system is in a slightly different position that doesnt seem to impact the rubber drive boots....touch wood!)
Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) Lefty-FRS Transmission and Driveline 13 02-09-2018 10:02 PM
aluminum drive shaft - anyone? Boofneenee Engine, Exhaust, Transmission 365 08-14-2016 08:40 AM
OEM drive shaft Baramzisyan Transmission and Driveline 13 03-22-2014 03:25 PM
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock Anthony@RWHP Transmission and Driveline 4 12-25-2013 08:09 PM
