Old 12-26-2021, 02:13 AM   #1
Ale3313
Drives: 2017 toyota 86
35:1 stft and p1264 code problem
Was on my way to work and got a check engine light while driving then the fuel was cut off by the computer and it threw a p1264 code. Started the car up and my throttle felt off as if the car was lacking power. Another thing when i was going back home i was idling at a stop light and the car read a positive 35:1 stft on oft. The car had a slightly rough idle and was like burping or misfiring or something and it went away when i drove off. Been on a 93 plus tune for months and had it retuned but the problem is still there. I have no clue about this, can anyone help me figure this out.
Ale3313 is offline   Reply With Quote
Old 12-26-2021, 02:55 AM   #2
tomm.brz
Drives: brz 2017 hksv2
positive maxed out stft can mean:
leak near lambda
leak in intake between the maf and the cylinders
damaged lambda
damaged maf
Old 12-27-2021, 02:51 AM   #3
Ale3313
Thanks found out it was an air leak. The previous owner didnt use hose clamps for some intake hoses which caused to leak over time.
The Following User Says Thank You to Ale3313 For This Useful Post:
p1l0t (12-27-2021)
misfire, p1264, problem, stft
LTFT + STFT very negative Idling, Oil dilution with gas smell problem FrickingReallySlow Engine, Exhaust, Transmission 0 07-26-2021 10:21 PM
LTFT/STFT on e85 ... CincyJohn Software Tuning 3 03-15-2021 03:05 PM
STFT/LTFT czellers Engine, Exhaust, Transmission 27 01-26-2021 06:45 AM
18% STFT WITH NO VACCUM LEAK Kris86 Software Tuning 0 05-22-2017 01:43 PM
Problem but no Code Jdoom Issues | Warranty | Recalls / TSB 9 01-13-2017 12:03 AM
