Old 12-28-2020, 04:49 PM   #1
czellers
czellers's Avatar
Drives: 2K19 GT86
STFT/LTFT
So, today I threw on the OFT(v2) Stage2+ tune, (I have a catless header). After the tune, I let it run for about 10 min, then easy/normal driving for 20 miles (city and highway). It runs a lot better now an feels stronger. My question is re: the STFT and LTFT numbers at idle as I plan to go e85 after this tank runs out...
czellers is offline   Reply With Quote
Old 12-28-2020, 05:08 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
For anybody who doesn't check new thread activity you'll want to use the software tuning Subforum 👍
https://www.ft86club.com/forums/forumdisplay.php?f=88
Video here to explain it. Looking for STFT to go up once E85 is in the lines.
Old 12-28-2020, 05:12 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You need to run more miles before starting to be concerned with making changes the ECU does a bit of learning. My big concern right away is your IAM is low. I would read the sticky's in the tuning subforum. You need to log injection mode and coolant temp as well.
Old 12-28-2020, 05:21 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This 100%. The IAM should be superglued at 1
Also (unrelated)- Domino's employee?
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 12-28-2020, 05:27 PM   #5
czellers
czellers's Avatar
Drives: 2K19 GT86
.... "IAM" ?
Old 12-28-2020, 05:34 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by czellers View Post
.... "IAM" ?
"Ignition Advanced Multiplier" seen as "Adv. Multiplier" on your screen.
Say you have 10 degrees of advance at XXXXRPM. If you IAM is .76 it takes that 10 degrees and multiplies it by .76, so you are only getting 7.6 degrees. Ideally it should be at 1.
Old 12-28-2020, 05:54 PM   #7
czellers
czellers's Avatar
Drives: 2K19 GT86
Hmm trying to work the math, as this picture is at 699 RPM (IDLE)
Old 12-28-2020, 05:55 PM   #8
czellers
czellers's Avatar
Drives: 2K19 GT86
Haha not a Dominos employee, why?
Old 12-28-2020, 06:06 PM   #9
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Idle is not in the equation. It`s Ignition adv. Times Adv. Multiplier, so 8.0 x 0.76
gen3v8 is offline   Reply With Quote
Old 12-28-2020, 06:07 PM   #10
czellers
czellers's Avatar
Drives: 2K19 GT86
Interestingly enough, in the video that was added to this thread, its in line with mine (while on premium gas as mine is also still on premium gas) with idle around 700 and the IAM bouncing between 6 and 8
Old 12-28-2020, 06:07 PM   #11
DarkPira7e
DarkPira7e's Avatar
The blue shirt and black pants... I did delivery a while ago for them. The FRS is perfect if you take out the passenger seat
Old 12-28-2020, 06:12 PM   #12
czellers
czellers's Avatar
Drives: 2K19 GT86
Oh ok, well as mine matches the IAM in the video, I think I'm good or otherwise I feel like that dude might have mentioned it?
Old 12-28-2020, 06:13 PM   #13
czellers
czellers's Avatar
Drives: 2K19 GT86
Ohh gotcha, just a coincidence I guess!
Old 12-28-2020, 06:15 PM   #14
steve99
OFT V4 tunes have IAM initial set to 0.7 so each startup iam reverts to 0.7 max, if fuel is good generally 93 then iam will get to 1 after 10 minutes or so of driving, if your on 91 or in canada it likely wont get to 1 due fuel quality.
the ltft is high positive are you on 10% ethanol fuel ?? or you might have minor exhaust leak or non standard intake ?
does the ltft get lower once your at say 2000 or so rpm ??
High negative STFT and LTFT 86TOYO2k17 Issues | Warranty | Recalls / TSB 22 09-30-2025 03:10 PM
Help with LTFT & STFT Stage 2 E85 OFT juniorrr Software Tuning 8 08-29-2021 09:53 PM
E85 normal LTFT and STFT Yitzb BRZ First-Gen (2012+) — General Topics 6 05-19-2020 06:11 AM
STFT and LTFT trims are negitive Coop Engine, Exhaust, Transmission 1 09-10-2018 03:26 PM
Is it normal for STFT and LTFT to always be 5% above? pcguru2000 Issues | Warranty | Recalls / TSB 3 04-13-2018 08:36 PM
