Drives: 2017 BRZ LMT w/ performance Pkg
HKS Hi-Power Single Racing V2 vs Spec L V2 (Dual)
I have a 17 BRZ limited with performance package and I can't make up my mind. I have been struggling with this decision for months now. I prefer NA setup. So far the only things I have changed are below
1. Mishimoto Induct Tube (Sound Generator Delete) 2. Michelin PS4S. got rid of stock tires after 4 years. 3. HKS Super Hybrid Intake Filter 4. Redline Full Synthetic Fluid for Rear Diff and Trans 5. Motul dot4 RBF for Brake Fulid 6. Nano Ceramic tint 7. 2 channel dash cam The last thing I wanna change is hks catback exhaust and I will leave everything else stock. Single V2 vs Dual V2? Single Racing V2 Pros 1. The lightest in HKS lineup 2. Cheap ($540) 3. Silencer Included so not too loud 4. Can expect most performance up 5. not sold in Japan Cons 1. Unbalanced look. (one hole is left empty) 2. Probably louder than spec l v2? Spec L V2 Pros 1. The best look in the lineup 2. light 3. not too loud (quieter than single racing v2?) cons 1. heavier than single racing 2. Expensive ($1000-1100) 3. Carbon Fiber tips discontinued (the one I wanted) Which one should I choose? PS= I don't go to track. It is the only car I have now and it is my daily. |
Drives: Red 2019 Subaru BRZ
So you are going to spend fairly heavily to change the sound? Am I missing something here? I'm very old.
friendly
Drives: 17' 86
https://thmotorsports.com/7589563-hk...n=OrderShipped
This is where I got mine from (it is not the carbon fiber as pictured, but the titanium) The dual canister is still fairly light, its moderately loud.
Seek comfort in discomfort.
#4 | |
Drives: 2014 Ultramarine FR-S
The weight difference between the systems isn't that big, only a 4.6lb difference (28.4 lbs for Single V2, 33 lbs for Spec-L2).
For the Spec-L2, you can purchase the carbon tips separately. Both systems rated at 90dB, but Spec-L2 slightly quieter at idle with 59dB vs Single V2's 65 dB. Biggest difference is the price and aesthetics, and also the material. The Spec-L2 uses higher quality 304SS which is more rust resistant than the Single V2's 409SS, which explains why it has a black coating, but there's a chance the black coating may peel/flake in the long run. I would personally go for the Spec-L2 between the two. Quote:
sound + look
#6 | |
decided to go with spec L V2 |
#7 | |
OK. Not something I care about. I did have a 69 Cutlass with a 502 and 3" pipes all the way, and it could set off car alarms in parked cars, anytime I wanted.
Drives: 2017 BRZ series.yellow
I have an original Spec-L on my 2017. Love it. Highly recommend.
LMGTFY
Drives: 13 FRS, 91 Miata
Your #4 Pro is not going to happen.
Unless you mean by just weight. |
#10 |
Purist
Drives: 2013 FRS - Hot Lava
I have the single exit V2. I love it. Its black and I prefer a single exit on a 4cyl. I bought a left side cutout cover.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#11 | |
Drives: 2018 Subaru BRZ
Spec L is a dream. Pairs perfectly with my catted headers. Their double resonated front pipe is also a great choice in the event that you decide to go catless headers because it will keep the drone/noise levels at a respectable level. I do have to warn you that they do drone a little. So it is advisable to upgrade your hangers to something thicker like JDM hangers. Is better to replace all 5 instead of the rear 2. Depending where you get them from, takes about a month to get them.
| Tags |
| hks. hi-power. |
| WTB: JDL or HKS Dual Resonated Front Pipe and HKS Hi-Power Spec-L | Import | Want-To-Buy Requests | 0 | 07-13-2021 06:25 PM |
| HKS Hi-Power Spec-L CBE (Ti-tips) and HKS dual resonated front pipe review | Pointmutation | Engine, Exhaust, Transmission | 8 | 06-16-2019 10:03 AM |
| WTB: HKS Hi Spec Power L Dual Exhaust (Ti Tips) | Berzerk | Want-To-Buy Requests | 0 | 06-26-2017 01:10 PM |
| HKS Hi-Power Single Racing Version | AznKirby | Engine, Exhaust, Transmission | 4 | 02-28-2014 09:44 PM |
| T1R 70R Version 2.0 Power exhaust single & dual ! | AJ PwR | Engine, Exhaust, Transmission | 11 | 07-12-2013 07:43 PM |
