Old 12-20-2021, 01:55 AM   #1
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
Wheel & Caliper Paint
I've got a "Pavement" color car with the 17" wheels on order. I want Bronze wheels but have nothing against the stockers except their color. How well do those "wheel paints" work? Am I seeing correctly that the wheels have silver spoke faces while the rest is black? After painting, will those areas look different?
I'd like to paint the brake calipers gloss black. Anyone have positive or negative experiences with caliper paint?
Lelandjt is offline   Reply With Quote
Old 12-20-2021, 07:06 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I used duplicolors wheel paint and clear a couple years ago. The base coat colors are fine. I find the clear coats too soft for wheels. 1k is easy the spray but it won't harden like 2K clear.
If I repainted my wheels again I'd use base coat from duplicolor and 2k clear coat.
I've used por-15 caliper paint kit in black. Good experience with it. Comes with everything needed from start to finish, minus a wire brush.
G2 kit is good too. Their kit comes with a hardnerer that is added to the can during application, meaning it's a one time use product.
Old 12-21-2021, 12:59 PM   #3
Lelandjt
Any other experience/opinions? I'm particularly concerned about the 2-tone wheels resulting in a bad looking finish.
Old 12-21-2021, 07:56 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
paint only ever looks as good as the skill of the painter.
if you're worried, talk to a local powder coater.
Old 12-22-2021, 08:28 AM   #5
Lelandjt
Ah, I hadn't thought of that option as cheaper than new wheels but better than DIY.
Old 12-23-2021, 08:16 AM   #6
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
For my last car the wheels that I got only came in black (which I didn't want). Had them powder coated a golden bronze as I figured powder coat would hold up better than paint. They held up pretty well. I think the coating was a little extra thick and was actually kind of soft based on how it looked when I managed to curb them a bit.
For the 2 tone wheels giving an imperfect finish I would think there are 3 things to keep in mind if painting: 1, is the 'raw' area a different texture? machine marks, etc. will need to be sanded out. 2, lay a good base layer. 3, Do as many coats as you think you need and then probably at least 1 more.
If you're having someone powder coat them, assuming these are hub centric, make sure they mask off the ID. You'd think they would know to do this, but not all places do.
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
jcw99 (12-23-2021)
Old 12-26-2021, 05:14 PM   #7
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Powder coating is not cheap. That money could be put towards new wheels. I only powder coated one set for my 04 WRX because they were old prodrive O.Z. That you can’t find easily. I would not spend to powder coat stock wheels. Get a new set that you want and DIY the stockers and use as winter wheels or sell if you don’t need a second set.
Ernest72 is offline   Reply With Quote
Caliper paint recommendations? Brink Cosmetic Modification (Interior/Exterior/Lighting) 17 03-16-2018 12:14 PM
Brake caliper paint WRB-DZA-BRZ Cosmetic Modification (Interior/Exterior/Lighting) 45 10-05-2016 01:02 PM
Caliper Covers vs Paint vleal12 CANADA 16 03-24-2015 01:48 PM
DIY - Caliper removal and paint olorin DIY (Do-It-Yourself) Guides 9 04-04-2014 10:12 AM
All in 1 Day - Plasti Dip Emblem & Wheel + Caliper Paint (First timer) Lverasky Cosmetic Modification (Interior/Exterior/Lighting) 26 10-22-2013 03:52 PM
