Old 12-18-2021, 08:27 PM   #1
nathand
Drives: 2016 HyperBlue
Track Wheels and TPMS
What are the suggestions for wheels that are used for autocross or track days (and possibly driving to and from the track). Put in TPMS sensors and clone the stock ones, or just go without the TPMS on the track tires?
nathand is offline   Reply With Quote
Old 12-18-2021, 08:30 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Go without. They’re really not needed anyway
The Following User Says Thank You to TommyW For This Useful Post:
nathand (12-22-2021)
Old 12-19-2021, 12:09 PM   #3
Autoxer62
Depends on if you drive to the event on them. I put cloned sensors in the autocross tires, I want to know if I pick something up while street driving.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following User Says Thank You to Autoxer62 For This Useful Post:
timurrrr (12-19-2021)
Old 12-19-2021, 01:06 PM   #4
Fletch
Drives: 2022 BRZ Limited
Couple of questions, sorry if they're stupid. I'm just researching new track wheels/tires for my first ever BRZ:
1. Why would you not want TPMS for the track? I know they're not really accurate but they seem useful as a ballpark guide. I've been using them in my other car.
2. If I get tirerack to install TPMS sensors in my new wheels will they be compatible with my '22 BRZ and work straight away? I assumed so, but the previous post about 'cloned sensors' has me second guessing..
Sorry if I'm hijacking the thread
Fletch is offline   Reply With Quote
Old 12-19-2021, 02:20 PM   #5
TommyW
TommyW's Avatar
At the track you're constantly monitoring pressures so tpms isn't really necessary. The light only comes on at a low pressure. As far as Tire Rack sensors that would be a question directed at them.
Old 12-19-2021, 02:52 PM   #6
Fletch
Ah now I get that the previous gen was just a warning system. I was thinking about a 4 wheel psi readout when I posted that.
The Following User Says Thank You to Fletch For This Useful Post:
strat61caster (12-19-2021)
Old 12-19-2021, 05:22 PM   #7
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Even '22 owners haven't yet figured out how to program non-OEM sensors to be picked up by the car. I wouldn't over-invest into that yet.
You can in fact read out the exact pressures via the CAN bus if you have a proper data logging system, but indeed it's not shown in the OEM instrument cluster. That may or may not be something why you'd want to have the TPMS sensors in the wheels.
timurrrr is offline   Reply With Quote
The Following User Says Thank You to timurrrr For This Useful Post:
Old 12-19-2021, 05:48 PM   #8
Fletch
Good info - thanks!
Old 12-19-2021, 06:47 PM   #9
strat61caster
strat61caster's Avatar
If that's true then that changes things. Modern sensors weigh almost nothing so if you've got the cash to burn go for it. I know on my old acura they're only off by <1psi from my gauge so if I were ever to beat on that car I would use them instead of getting out of the car.
Old cars with a dummy light that only triggers at like 25-26 psi were useless except to remind you to top off the tires when winter hit. Zero fucks given about spending money on sensors for that, just leave the light on it doesn't affect anything.
ineedyourdiddly
Old 12-19-2021, 08:07 PM   #10
Fletch
Yeah I can confirm the new gen has the 4 wheel psi display on the dash. I also have it on my other car and found it can be anywhere from 1psi up to 2-3psi out from my guage. But I personally still find it useful to monitor while im driving on track.
Old 12-20-2021, 10:03 AM   #11
cjd
cjd's Avatar
Drives: 2017 BRZ
I don't have sensors in any of my aftermarket wheels. Way too expensive for what they do. If I could use the dayta and they were a bit less, I'd think about it. Depends how easy it is to swap wheels. My wife's car displays PSI which is nice, but I have to do stuff with the scan gauge every time. Kinda a pain.
As long as they're consistent, you'll learn what pressures you want to see.
The Following 2 Users Say Thank You to cjd For This Useful Post:
nathand (12-22-2021), TommyW (12-20-2021)
Old 12-20-2021, 10:29 AM   #12
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Well firstly, the gen 1 didn't have anyway to actually display the real-time pressures without logging software. So basically the only thing they are good for on track wheels is lighting up the dashboard when it sees pressure go from 25 cold to 35+ hot in the matter of minutes (the GT86/BRZ might not have this issue, but other cars do).
Now, if you have a car that displays real-time pressure data in the infotainment or main display, then yeah I'd say get TPMS.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 01-11-2022, 02:48 PM   #13
deca
Drives: Halo 860
This is the first I've heard this but it makes perfect sense. I may have to look into getting this going on my Solo and finally pull the sensors out of my stock wheels.
deca is offline   Reply With Quote
Old 01-11-2022, 03:14 PM   #14
RedReplicant
Drives: None
How are you getting that? These are the channels I've got in AIM.
RedReplicant is offline   Reply With Quote
OK to run wheels with no TPMS in '17 BRZ? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 05-07-2018 06:23 PM
AZP May Specials:TPMS Reprogram/Clone, Track Day and Alignments AZP Installs Wheels and Tires 0 04-28-2014 11:00 PM
AZP May Specials:TPMS Reprogram/Clone, Track Day and Alignments AZP Installs Mechanical Maintenance and Tools 0 04-28-2014 11:00 PM
AZP May Specials:TPMS Reprogram/Clone, Track Day and Alignments AZP Installs NY / NJ / CT / PA 0 04-28-2014 10:59 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
