Drives: 2022 BRZ Limited on order
Brake pad recommendation
Took delivery of a 2022 BRZ a few days ago. Working on break in miles now. Haven’t owned anything other than a truck in about two decades. Having a blast so far. My son has a VW Golf we’ve taken to some track events, that lit the fire and pushed us to the BRZ.
So this will be a learning season. Track events and Autocross. The car will not be a daily driver. The only mod we want to do is brake pads and fluid for now. This fall after a summer driving the thing we will decide what the next step for the car will be. Can someone recommend a track day autocross pad please? My understanding is a pad never gets to temp at an autocross event, but with two of us sharing a car we will be pretty hard on them at a track day. Probably nothing that checks both of those boxes. Leaning toward the Ferodo DS2500. Advice? Edit: I have searched threads and read the other thread currently on the front page. |
Drives: 2013 GT86 fully standard
I think the DS2500 might get a short lifespan for a car that regularly sees track. I chose them for my gen1 since since the car must work as a daily aswell as on track, and they do work well from cold(even in - 17degC).which makes them great for autoX. But with more power and more weight the gen 2 maybe need something that can handle more temp would be more suitable, especially with car sharing.
Drives: Crapcan
CSG makes great pads, but they are pricey. Mike at CSG is running them on his gen 2 car already.
https://www.ft86club.com/forums/show...&postcount=114 I ran the C1's on my first gen and was pretty happy with them. I am trying out Raybestos pads this year. Dunno how those would handle AutoX though. You may end up running a different pad for each discipline.
Ive seen PFC08 doing great stuff on these cars aswell around here.
Drives: '13 Whiteout
I use Powerstop Trackday pads. They are really good. First set got 3 autocross and 4 track days. Current set is 8 track days and probably 3 more to go. I’ve heard lots of good things about the CSG pads and may give them a shot.
#6 | |
I see you are in SoCal - what sort of lap times were you subjecting them to? |
#7 | |
I'm an 8\10 driver Last edited by TommyW; 12-16-2021 at 02:44 PM. |
I liked carbotech xp10s as a track newb and they were good for the first stop at autocross as well, noisy on the street for me but zero problems driving the car to/from events. I could easily do <2m Laguna times all day long my second+third time there (1:54-1:56) on an otherwise stock car with 200tw tires (Z2ss, it was a long time ago now lol). Gloc R10 should be similar.
I like ds2500 for Street/autox, they'd survive a lapping day but only by the skin of their teeth imho. Might be fine for a few events as you get into it but I'd expect you wouldn't buy them again. |
#9 | |
Drives: Subaru BRZ / Toyota 86 Experts
When it comes to our stuff, we benchmarked almost all available racing/performance compounds on the brake dyno and on vehicle testing. Stiffness, pressure consistency, wear patterns, feedback, etc. are all judged accordingly. However, no other pad compound comes close to keeping the caliper temps under control and maintaining temp for the brake fluid. It's one of the reasons why our caliper temps tend to run nearly 100-150C lower than other competitive compounds. ![]() The 2022 BRZ is a bit harder than brakes simply because the car is just that much quicker. CP is a good light track, autocross, and excellent performer for daily applications. C2 F/R is excellent for heavy lapping days, racing, and medium enduro runs. |
#10 |
Drives: 2022 GR86
What tires do you plan to use at the track? I use GT Radial SX2. Having switched from CSG C1 to C2, I found C2 to be too much for those tires, and I'm thinking about switching my front pads back to C1.
PP Brembo calipers. Last edited by timurrrr; 12-16-2021 at 04:38 PM. Reason: Specified the calipers. |
#11 | |
#12 | |
A lot of folks have chimed in, but don't mention caliper. Your recommendation is specific to your use case, and your factory calipers. |
#13 | |
#14 | |
Maybe C2 then. It will be factory calipers until the fall. Will reevaluate entire status up then. Thank you |
| Recommendation for GTA PDR? | 1Cor10:23 | CANADA | 12 | 11-08-2014 09:08 PM |
| Brake pad and fluid install shop recommendation(south florida)? | becauseracecar1 | Southeast | 3 | 04-21-2014 10:32 AM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Non LED recommendation for DRL | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-11-2013 05:34 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
