Old 12-16-2021, 09:52 AM   #1
Angrypuppy
Drives: 2022 BRZ Limited on order
Brake pad recommendation
Took delivery of a 2022 BRZ a few days ago. Working on break in miles now. Haven’t owned anything other than a truck in about two decades. Having a blast so far. My son has a VW Golf we’ve taken to some track events, that lit the fire and pushed us to the BRZ.
So this will be a learning season. Track events and Autocross. The car will not be a daily driver. The only mod we want to do is brake pads and fluid for now. This fall after a summer driving the thing we will decide what the next step for the car will be.
Can someone recommend a track day autocross pad please? My understanding is a pad never gets to temp at an autocross event, but with two of us sharing a car we will be pretty hard on them at a track day. Probably nothing that checks both of those boxes. Leaning toward the Ferodo DS2500. Advice?
Edit: I have searched threads and read the other thread currently on the front page.
Angrypuppy is offline   Reply With Quote
Old 12-16-2021, 11:30 AM   #2
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
I think the DS2500 might get a short lifespan for a car that regularly sees track. I chose them for my gen1 since since the car must work as a daily aswell as on track, and they do work well from cold(even in - 17degC).which makes them great for autoX. But with more power and more weight the gen 2 maybe need something that can handle more temp would be more suitable, especially with car sharing.
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
The Following 2 Users Say Thank You to CedN For This Useful Post:
kevaughan (03-06-2022), strat61caster (12-16-2021)
Old 12-16-2021, 11:48 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
CSG makes great pads, but they are pricey. Mike at CSG is running them on his gen 2 car already.
https://www.ft86club.com/forums/show...&postcount=114
I ran the C1's on my first gen and was pretty happy with them. I am trying out Raybestos pads this year. Dunno how those would handle AutoX though. You may end up running a different pad for each discipline.
Old 12-16-2021, 11:51 AM   #4
CedN
CedN's Avatar
Ive seen PFC08 doing great stuff on these cars aswell around here.
Old 12-16-2021, 12:01 PM   #5
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I use Powerstop Trackday pads. They are really good. First set got 3 autocross and 4 track days. Current set is 8 track days and probably 3 more to go. I’ve heard lots of good things about the CSG pads and may give them a shot.
TommyW is offline   Reply With Quote
Old 12-16-2021, 01:34 PM   #6
Fletch
Thanks for the info! How long sessions were you doing? Any fade/heat issues?
I see you are in SoCal - what sort of lap times were you subjecting them to?
Fletch is offline   Reply With Quote
Old 12-16-2021, 02:18 PM   #7
TommyW
TommyW's Avatar
I run in the high 1:40s at Laguna, 1:30 at Streets and the other ones I'd have to check. They've been reliable as far as fade. I run Castrol SRF fluid, SS lines and slotted rotors now. Car STOPS! Once I dialed out the understeer and got rid of most of it the pads lasted longer.
I'm an 8\10 driver
The Following User Says Thank You to TommyW For This Useful Post:
SCFD (03-05-2022)
Old 12-16-2021, 02:20 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I liked carbotech xp10s as a track newb and they were good for the first stop at autocross as well, noisy on the street for me but zero problems driving the car to/from events. I could easily do <2m Laguna times all day long my second+third time there (1:54-1:56) on an otherwise stock car with 200tw tires (Z2ss, it was a long time ago now lol). Gloc R10 should be similar.
I like ds2500 for Street/autox, they'd survive a lapping day but only by the skin of their teeth imho. Might be fine for a few events as you get into it but I'd expect you wouldn't buy them again.
ineedyourdiddly
Old 12-16-2021, 02:24 PM   #9
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The recommendation is to go with a proper racing compound if you're planning to track. There are many different properties pertaining to setups and driving application. One major thing that separates us from the rest is that we're able to provide technical support while offering the latest advancements in brake compound technology. Tire tech is getting better, data is being shared, there is simply more access to track time now than ever before, and people are just getting quicker.
When it comes to our stuff, we benchmarked almost all available racing/performance compounds on the brake dyno and on vehicle testing. Stiffness, pressure consistency, wear patterns, feedback, etc. are all judged accordingly. However, no other pad compound comes close to keeping the caliper temps under control and maintaining temp for the brake fluid. It's one of the reasons why our caliper temps tend to run nearly 100-150C lower than other competitive compounds.
The 2022 BRZ is a bit harder than brakes simply because the car is just that much quicker. CP is a good light track, autocross, and excellent performer for daily applications. C2 F/R is excellent for heavy lapping days, racing, and medium enduro runs.
CounterSpace Garage is offline   Reply With Quote
The Following 4 Users Say Thank You to CounterSpace Garage For This Useful Post:
Angrypuppy (12-16-2021), brianbui23 (01-27-2022), TommyW (12-16-2021), ZDan (12-16-2021)
Old 12-16-2021, 03:14 PM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
What tires do you plan to use at the track? I use GT Radial SX2. Having switched from CSG C1 to C2, I found C2 to be too much for those tires, and I'm thinking about switching my front pads back to C1.
PP Brembo calipers.
Old 12-16-2021, 03:18 PM   #11
Fletch
I'm an 8\10 driver
Thanks great info!
Old 12-16-2021, 04:19 PM   #12
CSG Mike
CSG Mike's Avatar
Try the CSG C2 front/rear. It'll handle your track duty, but still have a wide enough operating temperature range to handle your AutoX without issue.
A lot of folks have chimed in, but don't mention caliper. Your recommendation is specific to your use case, and your factory calipers.
Old 12-16-2021, 04:46 PM   #13
Angrypuppy
Thank you. Might try the CP.
Old 12-16-2021, 04:48 PM   #14
Angrypuppy
Just saw this after I posted CP.
Maybe C2 then. It will be factory calipers until the fall. Will reevaluate entire status up then.
Thank you
Recommendation for GTA PDR? 1Cor10:23 CANADA 12 11-08-2014 09:08 PM
Brake pad and fluid install shop recommendation(south florida)? becauseracecar1 Southeast 3 04-21-2014 10:32 AM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 05:34 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
