Drives: 2014 base manual Raven FR-S
Ripped wire in engine bay?
Was changing my spark plugs and found this green fabricy wire that looks like it was ripped off of something, the other side of it seems to be attached to the lower part of the frame on a bolt. Other side of the car has the same thing and it is connected to what looks like some cover/sensor on the bottom front of the motor… seems to be a ground? I have no issues with the car at all from it… anyone know what it connects to and how important it is to fix? Thanks
After doing some more research I believe it is a grounding wire... I guess there's enough other ground wires that this one isn't totally necessary. I'll have to go in there and see how hard it's going to be to fix
Drives: 2016 BRZ
It's super easy once the under tray is removed.
Wheels for Brains
It's not really a wire in the normal sense. It's a braided metal strap. You can probably get a replacement at a dealer and install it. It uses 2 loop terminals and bolts onto the engine block and chassis
| I think I got ripped off... :( | Omnivus | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 12-02-2019 03:26 PM |
| handbrake wire and reverse wire location Australia gt86 | rsingh | Electronics | Audio | NAV | Infotainment | 0 | 01-16-2017 09:12 PM |
| Ripped wire out of plug | 15limited | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 10-23-2015 07:48 PM |
| Help me identify this wire! Extra wire around battery after clutch job | YouShallKnow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 12-09-2014 02:04 PM |
| Reverse Wire Tap wire Location? | Norkoastal | Electronics | Audio | NAV | Infotainment | 2 | 10-19-2012 10:22 AM |
