Old 12-02-2021, 07:33 PM   #1
Lim
Drives: Scion FRS 2016
Question Need help with shock absorber
I have noticed a bit of oil just a smuge on right rear shock absorber.
I bought new one for my FRS at Toyota with self lock nut
I brought it to 3rd party mechanic shop to install.
I figured it should be simple job.
They installed it and it was fine for two days.
On third day I heard sound coming from it and after checking all shock absorber was covered in oil and had a puddle on a ground.
Obviously somehow they screw it up. I will go back to them tomorrow, but what they could have done wrong?
Is there any trick to lock nut?
Also Toyota did not have lock nut so I bought it from Subaru for BRZ. It looked the same
I have FRS 2016 does it has the same shock absorber as BRZ 2016? If Toyota does not have this part can I use BRZ one?
Thanks.
Lim is offline   Reply With Quote
Old 12-02-2021, 10:13 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Thanks.
I have heard stories of mechanics using a rattle gun on the top nut to do it up and it damaging the piston seals by over spinning the shaft but I think that is exceeding rare.
The subaru unit should be a direct equivalent.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Lim (12-03-2021)
Ask for help about the abnormal noise of Ohlins shock absorber MarsCar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-18-2021 09:42 PM
Oem shock absorber lasting? Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 04-11-2017 12:21 PM
Raceseng Shock Top - Rear Upper Shock Mount with 1” Increased Travel RJasonKlein Brakes, Suspension, Chassis 2 01-18-2017 04:33 PM
What can you learn from a shock dyno chart? Or shock dyno 101 Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 03-01-2016 07:40 AM
