Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-01-2021, 11:42 AM   #1
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
Active Sound Control
I downloaded the owner’s manual for the 2022 BRZ to familiarize myself with some of the differences from my 2017 BRZ. I had that silly sound snorkel gizmo capped off and at one time completely removed. I called it the Toyobaru Kazoo. When I first saw under the hood that the Kazoo was gone I said, “Oh joy, no more wheezing and snoring.” Wrong. Now we have the 21st Century version. Following is an excerpt from the manual. Does anyone know if turning off the engine sound is by physically yanking a plug or is the some secret handshake involved where you push a sequence of buttons to enter a hidden menu? My 2014 Forester radio had a hidden menu for making profile changes, so that got me thinking there is a less intrusive way to disable the sound (AKA noise)?
7-8. Active Sound Control
The active sound control provides dynamic engine sounds. When driving with Sport mode selected, the engine sounds will be particularly loud.
NOTE
The operational/non-operational setting of the Active Sound Control can be changed by a SUBARU dealer. Contact your SUBARU dealer for details.
Flarpswitch is offline   Reply With Quote
Old 12-01-2021, 11:59 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The end user has no menu to turn it off with. I did find the plug for the sound control unit on the left hand side of the dash. You have to have the passenger door open to remove the end cap to gain access to the plug. Then you can just disconnect it if you wish.
dragoontwo is offline   Reply With Quote
Old 12-01-2021, 12:07 PM   #3
jvincent
jvincent's Avatar
You can see it on the part diagram. "Sound Creator ECU"
And the associated speaker is shown here.
Old 12-01-2021, 12:18 PM   #4
McMCOO
Anti-Social Media
McMCOO's Avatar
Drives: 24 GR86 Premium MT is on the way!
I bought a Carista OBD2 dongle that changed lots of dealer-level stuff on my 2020. I silenced the seatbelt chime, killed headlights immediately when the engine was shut off, etc. I wouldn't be surprised if the sound generator would be on the Carista menu once the 2022, is supported.
McMCOO is offline   Reply With Quote
The Following User Says Thank You to McMCOO For This Useful Post:
timurrrr (12-01-2021)
Old 12-01-2021, 05:39 PM   #5
Flarpswitch
Maybe my OBD II module and app can address that feature when it comes time. It would be cool if a simple hard wired switch would work. Looking a the diagram, it appears that the Aux Unit plugs into the Sound Creator. If a plug or plugs are disconnected, is that going to create a problem? Is there a dedicated speaker or does the augmented sound appear on all the speakers? It might be best to tell the dealer to deliver my new car with it turned off. If the sound creator synthesizes the sound based on input from the engine control module and not an amplified microphone, why not go the next step and have a menu of sounds on the head unit to choose from? The BRZ could sound like any kind of exotic car or a starship with warp drive. I would go for something absurd like the Big Boy steam engine or the sound playing cards make when they are attached to the forks of your bicycle and rub on the spokes. Useless accessory that does not make the car go faster.
Old 12-01-2021, 05:46 PM   #6
McMCOO
Anti-Social Media
McMCOO's Avatar
Oh! Pod racers. TIE fighter.
The Following 2 Users Say Thank You to McMCOO For This Useful Post:
Flarpswitch (12-01-2021), mike2100 (04-28-2022)
Old 12-01-2021, 05:48 PM   #7
CZ6T
Drives: 2022 crystal white BRZ
If you open the passenger side door, there's a trim piece that covers the side of the glovebox/dash. under the bottom of the panel is a little slot you can put a screwdriver wrapped in tape and pry outwards to pop the panel off.
Behind the panel is the engine speaker amplifier, and you can take a flathead screwdriver and push in on the connector and pull down to disconnect it. That will disable the engine speaker, and then if you decide to re-enable it you can just plug the connector back in.
I attached a couple pictures to help visualize what I'm referring to.
CZ6T is offline   Reply With Quote
The Following 10 Users Say Thank You to CZ6T For This Useful Post:
Ash_89 (12-10-2021), DocWalt (12-02-2021), Dylans47 (12-03-2021), jvincent (12-01-2021), McMCOO (12-01-2021), Pete (12-02-2021), Quagmire (12-02-2021), Simmons (12-02-2021), tenderization (12-02-2021), timurrrr (12-01-2021)
Old 12-02-2021, 07:38 AM   #8
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
I asked the dealer to just turn this off for me before I picked up the BRZ. He said it was just a checkbox in their software to enable/disable it.
Rossman is offline   Reply With Quote
The Following User Says Thank You to Rossman For This Useful Post:
StE92ve (12-02-2021)
Old 12-02-2021, 01:14 PM   #9
Flarpswitch
So, the least intrusive way is to just have the dealer turn it off. Looking at the diagram, Part #86301AB, what is that? I read somewhere that it could be a separate speaker from the audio system for the Sound Creator ECU. Is that true? Did the marketing people and Toyobaru do some sort of survey that said, "Hell yeah, we want testosterone pumping noise." If they went to all the trouble of putting that gizmo in, the least they could have done is put a switch in the glove box or under the dash where you can opt-in or opt-out. Or, how about this: do a bypass on the output of the Sound Creator and connect to a massive amplifier mounted in the trunk and find a place on the OUTSIDE of the car for one or more speakers. Can you say "RICER"?
Old 12-02-2021, 01:59 PM   #10
Flarpswitch
I just looked up the parts and it looks like the Sound Creator ECU (MSRP $336.70) is connected to a single speaker (MSRP $111.70). Really? Would it have been unreasonable to apply that cost to an upgrade to the sound system? Tires? Fancy lug nuts? Get out of jail card?
The Following 6 Users Say Thank You to Flarpswitch For This Useful Post:
22 BRZ (12-02-2021), bcj (12-03-2021), Bristecom (07-14-2022), Stigmaru (04-24-2022), tenderization (12-02-2021), timurrrr (12-02-2021)
Old 12-02-2021, 03:58 PM   #11
tenderization
Drives: 88 RX-7, 2022 BRZ
My plan is to resist the temptation to ask for it disabled when picking the car up and waiting until at least the first oil change...
tenderization is offline   Reply With Quote
Old 12-02-2021, 04:08 PM   #12
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Renault is way ahead of you, they did this years ago with one of their hot hatches - I remember a Top Gear reviewer going through the various options. Nothing as extreme as what you suggest but you could make the car sound like anything from a V8 muscle car to a high-revving formula racer.
Sport-Tech is offline   Reply With Quote
Old 12-02-2021, 10:31 PM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by BlkTrax View Post
Yes I have access to the SSM4 dealer tool
Could you sniff the CAN bus messages used to enable/disable, so that others with the right skills and basic electronic tools could DIY that?
timurrrr is offline   Reply With Quote
Old 12-03-2021, 08:09 AM   #14
dragoontwo
dragoontwo's Avatar
According to the service info; the speaker is right in front of the shifter and is just a 2 wire connector. Where as the ecu is on the CAN network.
Can confirm the speaker info. I removed mine.
Full Active With Widebands? Skippman Electronics | Audio | NAV | Infotainment 47 04-22-2020 09:42 PM
Staggered tires can cause over-active traction control issues KoolBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 12-23-2015 02:01 PM
3 Way Active without a Subwoofer stea1thbear Electronics | Audio | NAV | Infotainment 42 10-14-2013 02:03 AM
Need advice...removing active sub Fizz Electronics | Audio | NAV | Infotainment 5 10-07-2013 10:26 AM
A more active mid alantic _F-R-S_ Mid-Atlantic 37 11-12-2012 07:19 AM
