CANADA Canada
Old 11-19-2021, 01:59 PM   #1
still2slik
still2slik's Avatar
Drives: 2017 Brz
LS Swap shop recommendations
hey guys, just wondering if anyone has any shop recommendations for an LS swap in the GTA (greater toronto area). Im not looking to spend an arm and a leg. i spoke to a shop last year that said they can do it for 10-12, but i lost their contact. Anyone here have any recommendations? Thanks for your time and consideration.
still2slik is offline   Reply With Quote
Old 12-02-2021, 03:59 PM   #2
wparsons
wparsons's Avatar
There's simply no way a shop is doing a turn key LS swap for anything remotely close to that with everything working. Most turn key LS swaps with everything working correctly are in the $25k US range.
The parts alone, not including engine, for a K swap are $10k and that uses the stock gearbox. An LS swap will need a much stronger gearbox that will be upwards of $5k alone.
If you're doing it for a pure race car and it doesn't need PS, and can run a racepak type dash instead of having the stock one work you can save a bit, but it still won't be cheap.
If you want a shop that'll do excellent work and has experience with lots of swaps, contact NV Auto outside Hamilton.
flickr
Old 12-02-2021, 05:00 PM   #3
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
+1 for NV Auto, but it will be well over the 10-12k budget unless you're somehow getting the parts for free.99 and don't care about power steering, ac, oem dash, or chassis harness integration.
villainous_frx is offline   Reply With Quote
Shop recommendations in SF Bay area to do a swap? 86fun Engine Swaps 23 02-08-2019 09:57 AM
Shop Recommendations? Jajanken86 Northwest 0 10-29-2018 05:57 PM
Shop Recommendations DatBackflipTho Mid-Atlantic 6 09-20-2017 08:44 AM
PDX Shop Recommendations Crazy Drew Northwest 1 03-25-2015 02:17 PM
Any recommendations on a shop in San Diego to do spring swap? 355rockit Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-11-2014 02:43 PM
