Drives: Series.Blue
Hello,
I just got my OLM headlights with HID's yesterday. I test tested them out and everything worked fine. Later that evening I go to fully install them and everything but the high and low beams work. The boomerang and turn signals work just fine. I was thinking that maybe I blew a fuse but I plugged back in the stock headlights and they worked just fine. Any suggestions would be greatly appreciated. How I have my Ballast connected to the headlight; https://imgur.com/stiINfa Then the other two connectors just plugged into the car's headlight harnesses; https://imgur.com/ruyvwnH Edit: I've connected a voltmeter to the plug that comes out of the headlight and plugs into the ballast and it reads that is has power when the headlights are turned on, but for some reason the power isnt making it through the ballast. I'm kinda confused because it was working before and now it's not. Also, neither side are working. So I'm not too sure what the likely hood of BOTH ballasts being pretty much DOA is but I imagine it isn't very high, lol. Last edited by FineVisionz; 11-16-2021 at 12:04 PM. |
Drives: 2019 Toyota 86 TRD SE
Flip the harness leading into the ballast.
LMGTFY
Drives: 13 FRS, 91 Miata
#5 | |
Drives: Series.Blue
![]() To be fair, the design for the plug is also kinda dumb. It has a tab on either side for the male side to clip onto allowing you to plug it in backwards. (if that makes sense) I first read this message and I thought, "No way this can be done" Haha, thanks for pointing out the obvious for me, lol. Cheers ![]()
No worries. The harnesses are like that on a lot of HID kits. I’ve made that mistake on both my wife’s Camry and my 86. I thought the same thing. “Could it be that the harness is flipped?… fuck me holy shit it worked!” Lol.
| Tags |
| headlights, issues, olm |
| BRZ headlight shroud inside FRS headlight? | S84kam | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 04-02-2016 12:24 AM |
| Winjet headlight signal issues | Demotic | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 09-21-2015 11:03 PM |
| Monogram headlight issues | Simon | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 10-28-2014 10:48 AM |
| HID Headlight Issues | KkSc | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 02-10-2014 04:23 PM |
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 03:32 PM |
