Old 11-16-2021, 10:46 AM   #1
FineVisionz
FineVisionz's Avatar
Drives: Series.Blue
Exclamation OLM Headlight issues
Hello,
I just got my OLM headlights with HID's yesterday. I test tested them out and everything worked fine. Later that evening I go to fully install them and everything but the high and low beams work. The boomerang and turn signals work just fine.
I was thinking that maybe I blew a fuse but I plugged back in the stock headlights and they worked just fine.
Any suggestions would be greatly appreciated.
How I have my Ballast connected to the headlight;
https://imgur.com/stiINfa
Then the other two connectors just plugged into the car's headlight harnesses;
https://imgur.com/ruyvwnH
Edit: I've connected a voltmeter to the plug that comes out of the headlight and plugs into the ballast and it reads that is has power when the headlights are turned on, but for some reason the power isnt making it through the ballast. I'm kinda confused because it was working before and now it's not. Also, neither side are working. So I'm not too sure what the likely hood of BOTH ballasts being pretty much DOA is but I imagine it isn't very high, lol.
FineVisionz is offline   Reply With Quote
Old 11-16-2021, 10:12 PM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Flip the harness leading into the ballast.
Drifter X is offline   Reply With Quote
Old 11-17-2021, 02:13 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If not that Ballast is DOA probably
Old 11-17-2021, 11:09 AM   #4
Drifter X
Drifter X's Avatar
Chee hee
Old 11-18-2021, 11:16 AM   #5
FineVisionz
Drives: Series.Blue
Talking
Holy shit, I'm so dumb. This worked, thank you so much.
To be fair, the design for the plug is also kinda dumb. It has a tab on either side for the male side to clip onto allowing you to plug it in backwards. (if that makes sense)
I first read this message and I thought, "No way this can be done"
Haha, thanks for pointing out the obvious for me, lol.
Cheers
Old 11-18-2021, 01:43 PM   #6
Drifter X
Drifter X's Avatar
No worries. The harnesses are like that on a lot of HID kits. I’ve made that mistake on both my wife’s Camry and my 86. I thought the same thing. “Could it be that the harness is flipped?… fuck me holy shit it worked!” Lol.
headlights, issues, olm
BRZ headlight shroud inside FRS headlight? S84kam Cosmetic Modification (Interior/Exterior/Lighting) 9 04-02-2016 12:24 AM
Winjet headlight signal issues Demotic Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2015 11:03 PM
Monogram headlight issues Simon Cosmetic Modification (Interior/Exterior/Lighting) 8 10-28-2014 10:48 AM
HID Headlight Issues KkSc Cosmetic Modification (Interior/Exterior/Lighting) 5 02-10-2014 04:23 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
