Old 11-10-2021, 05:55 AM   #1
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
Exhaust Compatible with Gen 1???
During this SEMA video that FTSPEED just put up yesterday, around the five minute mark @thekevinvo mentions that the exhaust is compatible with the previous model... Are you saying that the exhaust is the same on both Gen 1 and Gen 2 cars???
Current: 2013 Scion FRS - Whiteout
knapper is offline   Reply With Quote
Old 11-10-2021, 07:25 AM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Stock clearance?
Even if you could install an old exhaust without issues, it doesn't mean is suitable for the new car. A bigger engine means that it'll need a bigger exhaust size and a new analysis of the gas flow and supression of the sound waves. Wait until new exhausts are available for the new car.
Old 11-10-2021, 11:50 AM   #3
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
https://www.ft86club.com/forums/show...23#post3480023
timurrrr is offline   Reply With Quote
Old 11-12-2021, 12:08 PM   #4
thekevinvo
Drives: 2014 Scion FRS
The mounting and hanger locations seem to be the same. However, like others have mentioned, the existing exhaust parts might not offer the best performance as they're not designed for the new engine.
Take this with a grain of salt, but I also believe I heard Cusco say the old headers may fit as well, but that also goes back to what I said above.
Once I know more, I'll be sure to share!
thekevinvo is offline   Reply With Quote
The Following 2 Users Say Thank You to thekevinvo For This Useful Post:
knapper (11-14-2021), timurrrr (11-12-2021)
Old 11-12-2021, 05:55 PM   #5
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
But for NA the cat back rarely offer any benefits other than sound or looks. So if it fits I am sure it will be just fine.
Ernest72 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ernest72 For This Useful Post:
PulsarBeeerz (11-13-2021), timurrrr (11-12-2021)
Old 11-13-2021, 10:34 AM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
STI says you can have a 13% lower back pressure with their axleback and 16% lower back pressure with their axleback and a bigger midpipe. Meaning that you can get an additional ~3% with the midpipe which is not much of an increase and it adds noise. How much is the total improvement on hp benefits? It has not been measured, but at least it is one of the very few manufacturers posting numbers. Other exhaust manufacturers will not post anything or they'll post some dyno sheet which is very easy to manipulate. Fact is that NA tuning doesn't give much, but every little you can gain counts. If someone doesn't want to pay big money in overall NA tuning, then I agree he should focus on an exhaust mainly on the sound and the looks.
Old 11-13-2021, 12:49 PM   #7
PulsarBeeerz
Drives: JRSC BRZ SOLD
Agreed, catbacks get into diminishing returns quickly until you lessen restrictions upstream at the header on back and most importantly tune for it. There is basically no performance benefit after the mid pipe apart from sound as we know.
PulsarBeeerz is offline   Reply With Quote
Old 11-14-2021, 02:44 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If you want to go catless yes, but it is a decision. Personally I would never do it. Same about a catted aftermarket header which does not gain much and there were many people complaining (non-public) that the sport cat is failing after a short time. I find the factory +'17 header to be quite optimal and you keep the OEM heat shielding too. About the new model we'll have to wait and see, but I am sure some will want to go catless no matter what.
The Following User Says Thank You to nikitopo For This Useful Post:
Yoshoobaroo (11-14-2021)
Old 11-14-2021, 09:43 PM   #9
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
Yes, Gen 1 cat-back fits on Gen 2
www.ft86club.com/forums/showthread.php?t=147582
Originally Posted by trippinbillies40 View Post
Here's my car with a 3" resonated Perrin cat back that was a Gen 1 system, direct bolt on with no modifications required.
Lightened is offline   Reply With Quote
The Following 4 Users Say Thank You to Lightened For This Useful Post:
DriveDriftDogfight86 (11-25-2021), finch1750 (11-18-2021), funwheeldrive (12-13-2021), jflogerzi (11-15-2021)
Old 11-18-2021, 02:41 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Sound tuning sure maybe get something new, but pretty sure its gonna be 2.5", 3", or 60mm like always for pipe diameter.
Old 12-13-2021, 10:25 PM   #11
saltywetman
Drives: 2020 Toyota 86 GT 6M
the fa24 in second gen is essentially a bored out fa20 correct? if so, barring clearance from changes with suspension arms the header, op, etc may bolt right up! I'd be tempted to get a second gen if i can transfer over my coils, brakes, and exhaust
saltywetman is offline   Reply With Quote
How Compatible are The FR-S BRZ 86 models? jess'sfrs Scion FR-S / Toyota 86 GT86 General Forum 5 09-29-2021 10:57 AM
Galaxy s6 not compatible with USB??? MisterSheep Electronics | Audio | NAV | Infotainment 11 09-23-2015 07:58 PM
Which Supercharger is Compatible with AT F1fletch Forced Induction 17 01-08-2014 11:49 AM
Is Automatic compatible with the BRZ? goshem BRZ First-Gen (2012+) — General Topics 10 12-03-2013 01:29 PM
New iPods compatible? ThePoet Electronics | Audio | NAV | Infotainment 5 12-23-2012 01:39 PM
