Old 11-07-2021, 10:25 AM   #1
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Adjusting window regulator
Does anyone have a diagram of the window regulator and how to adjust it correctly?
The window regulator was replaced just prior to the warranty expiring, but is in need of adjustment. The tint has been scratched on the inside of the glass.
I'm going to fiddle with it soon while replacing the door speakers.
Old 11-07-2021, 11:20 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i believe you need to adjust the grip of the felt pads inside the door, and not the regulator to correct that.
Switched out window regulator. Now my window decided that this will be its max height kev0 Issues | Warranty | Recalls / TSB 13 07-21-2021 09:10 PM
DIY: Window Motor & Regulator Replacement thekevinvo DIY (Do-It-Yourself) Guides 0 09-03-2020 02:46 PM
Fuel Regulator tofurun Forced Induction 9 01-09-2017 09:11 PM
Window Regulator Bolts/Washers - TSB and new parts? PollosHermanos Issues | Warranty | Recalls / TSB 3 03-08-2014 01:17 PM
Window Regulator Mounting Bolts - Noise Issue & Part Revision? PollosHermanos Issues | Warranty | Recalls / TSB 1 03-06-2014 10:39 AM
