Old 11-04-2021, 03:47 AM   #1
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Toyota 86 steering wheel plug and play?
Have a 2014 frs without volume controls.
I’m wanting to see if it’s possible to swap on a Toyota 86 steering wheel with volume controls.
Reason I’m asking is because I just pulled the trigger on a Joying 10.1 1920*1200 6g+128gb head unit and it’s apparently a pain to change volume on it without physical controls.
Two questions…will it be an easy plug and play with minor wiring to the head unit?
And
Will these wheel controls work?
Also
Getting rid of these pesky Scion badges makes me feel happy. Hopefully it’s possible.
Appreciated.
Celigts is offline   Reply With Quote
Old 11-19-2021, 01:01 PM   #2
Celigts
Celigts's Avatar
Looking to use this steering wheel. What would I need? Will my 2014 airbag swap over? Thanks!
Old 11-19-2021, 09:29 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
you need to re-wire the entire steering column. i believe it's all integral, and would require complete replacement.
no, you can't re-use your airbag. they're different sizes.
V8 plug and play ECU smudge Engine Swaps 7 02-04-2018 02:23 PM
Can I plug and play this amp? 7thgear Electronics | Audio | NAV | Infotainment 4 04-11-2015 04:26 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
