Old 10-31-2021, 04:05 PM   #1
aphexgt
Drives: 2017 brz
Click sound on cold start
Hey guys, been having this loud click sound on cold starts, usually when it has sat for a day or so. Car is driving fine otherwise at around 50k miles. Any ideas what this could be? 2017 BRZ 6MT
aphexgt is offline   Reply With Quote
The Following User Says Thank You to aphexgt For This Useful Post:
humfrz (10-31-2021)
Old 10-31-2021, 04:44 PM   #2
humfrz
Welcome to the forum, there, aphexgt -
I have no idea what is causing that sound, but I wouldn't worry about it unless it gets worse.
Is your car an AT or MT?
Do you have any power mods?
Old 10-31-2021, 05:14 PM   #3
aphexgt
Drives: 2017 brz
Thanks! Coming from a chevy spark so real excited to finally have something I enjoy, and its an MT that's entirely stock !
humfrz (10-31-2021)
Old 10-31-2021, 06:00 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Does it have automatic door locks?
Old 10-31-2021, 07:24 PM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I'm not hearing any loud clicks even with headphones. I hear the normal sound of the steering lock retracting, a normal cranking sound, a normal rev up, a normal chime, I hear the engine stumbling and picking back up, then it goes back to running normally with a normal sound, no clicks.
Old 10-31-2021, 08:38 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
it would do that if he let out the clutch after starting, but leaving the transmission in neutral. mine does the same thing, but it's more a driver-mod than a car-mod.
i will start it, let off the clutch, it stutters for a second while spinning up the input shaft, do all my pre-checks, fasten my seatbelt, then get on the brake, let off the parking brake, and put it in gear, and go.
it's how i let the car warm up a little before actually moving it.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (11-01-2021), Ultramaroon (11-01-2021)
Old 10-31-2021, 10:39 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Is it that knocking sound for maybe the first half second after it fires up?
Old 10-31-2021, 11:39 PM   #8
aphexgt
Drives: 2017 brz
hmm I do do this but I start the car other times and it doesn't happen at all and sometimes after a couple hours but not a full day, it makes the same stumbling noise as stated above, just a little less noticeable
Old 10-31-2021, 11:40 PM   #9
aphexgt
Drives: 2017 brz
yes! that's what I'm referring to, kinda sounds like the engine stops for a split second then proceeds as normal
Old 11-01-2021, 12:06 AM   #10
Ultramaroon
not playing cards
Oh, yeah! I hear it now. Is this thing bone stock? For how long has it been doing that?
Old 11-01-2021, 12:10 AM   #11
aphexgt
Drives: 2017 brz
completely! runs and drives perfectly normal as well, this is the only weird thing that I can't quite figure out after pouring through tons of forums and youtube videos
Old 11-01-2021, 12:18 AM   #12
Ultramaroon
not playing cards
Only on a cold start? Hmmm... Ever tried to wait until the fuel pump quits priming? Just a thought.
Old 11-01-2021, 05:48 AM   #13
RZNT4R
It would do that if he had molasses in the transmission.
I mean, cold start yeah, but it's not like the weather is frigid in late october. I get a drop like that when it's nearing -20C. Then again, I drained the factory goop out of my trans at 12000km and I've been running Amsoil 75W90 since.
Old 11-01-2021, 01:18 PM   #14
aphexgt
Drives: 2017 brz
haven't heard of that until this post, just tried it this afternoon when it usually would have made the noise and nothing... Think you may have solved it, I usually just turn it on immediately, never knew I had to press the button without clutch and brake to prime. Will continue to do this and update if the problem persists. Thanks for your help!!
FRS 2015 Cold Start Sound. Feronous Engine, Exhaust, Transmission 16 07-10-2018 10:04 PM
Grind sound on Cold start japes Issues | Warranty | Recalls / TSB 12 07-07-2016 08:58 PM
Cold Start, engine makes loud pop sound BTXP.XD Issues | Warranty | Recalls / TSB 10 05-20-2015 10:32 PM
Rattle sound on cold start Frs32907 Issues | Warranty | Recalls / TSB 0 07-12-2014 10:36 AM
rattle sound cold start marky Issues | Warranty | Recalls / TSB 1 03-24-2014 06:16 PM
