Drives: 2017 brz
Click sound on cold start
Hey guys, been having this loud click sound on cold starts, usually when it has sat for a day or so. Car is driving fine otherwise at around 50k miles. Any ideas what this could be? 2017 BRZ 6MT
| The Following User Says Thank You to aphexgt For This Useful Post: | humfrz (10-31-2021) |
#2 | |
![]() I have no idea what is causing that sound, but I wouldn't worry about it unless it gets worse. Is your car an AT or MT? Do you have any power mods? |
#3 | |
Drives: 2017 brz
Thanks! Coming from a chevy spark so real excited to finally have something I enjoy, and its an MT that's entirely stock ! |
#4 |
Drives: 2013 frs base
Does it have automatic door locks?
#5 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I'm not hearing any loud clicks even with headphones. I hear the normal sound of the steering lock retracting, a normal cranking sound, a normal rev up, a normal chime, I hear the engine stumbling and picking back up, then it goes back to running normally with a normal sound, no clicks.
#6 |
ProCrastinationConsultant
it would do that if he let out the clutch after starting, but leaving the transmission in neutral. mine does the same thing, but it's more a driver-mod than a car-mod.
i will start it, let off the clutch, it stutters for a second while spinning up the input shaft, do all my pre-checks, fasten my seatbelt, then get on the brake, let off the parking brake, and put it in gear, and go. it's how i let the car warm up a little before actually moving it.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | humfrz (11-01-2021), Ultramaroon (11-01-2021) |
#7 |
Is it that knocking sound for maybe the first half second after it fires up?
#8 | |
Drives: 2017 brz
hmm I do do this but I start the car other times and it doesn't happen at all and sometimes after a couple hours but not a full day, it makes the same stumbling noise as stated above, just a little less noticeable |
#9 |
Drives: 2017 brz
#10 |
Oh, yeah! I hear it now. Is this thing bone stock? For how long has it been doing that?
#11 |
Drives: 2017 brz
#12 |
Only on a cold start? Hmmm... Ever tried to wait until the fuel pump quits priming? Just a thought.
#13 | |
I mean, cold start yeah, but it's not like the weather is frigid in late october. I get a drop like that when it's nearing -20C. Then again, I drained the factory goop out of my trans at 12000km and I've been running Amsoil 75W90 since. |
#14 |
Drives: 2017 brz
haven't heard of that until this post, just tried it this afternoon when it usually would have made the noise and nothing... Think you may have solved it, I usually just turn it on immediately, never knew I had to press the button without clutch and brake to prime. Will continue to do this and update if the problem persists. Thanks for your help!!
| FRS 2015 Cold Start Sound. | Feronous | Engine, Exhaust, Transmission | 16 | 07-10-2018 10:04 PM |
| Grind sound on Cold start | japes | Issues | Warranty | Recalls / TSB | 12 | 07-07-2016 08:58 PM |
| Cold Start, engine makes loud pop sound | BTXP.XD | Issues | Warranty | Recalls / TSB | 10 | 05-20-2015 10:32 PM |
| Rattle sound on cold start | Frs32907 | Issues | Warranty | Recalls / TSB | 0 | 07-12-2014 10:36 AM |
| rattle sound cold start | marky | Issues | Warranty | Recalls / TSB | 1 | 03-24-2014 06:16 PM |
