Drives: '13 Whiteout
Front Splitter Adjustment
I had a front splitter installed however when checking the angle of attack it was tilted backwards. Apparently the optimum angle is between .5 and 5 degrees tilted forward. I have the rods maxed out at 2 degrees backwards of level. Am I splitting hairs or not?. It seems a backwards angle would just cause lift at the front.
AutoX-10/10ths every run
I always tried to have mine level to the ground when the car was at its resting ride height. Having the front tilted up does seem to be less than ideal when generating down force. One thing I would consider though is under braking when the front of the car is diving a tilted up splitter may actually approach a zero angle relative to the ground. One issue I sometimes encountered was a splitter that was level to the ground would sometimes hit the ground under braking situations depending on the slope of the ground.
| The Following User Says Thank You to whataboutbob For This Useful Post: | TommyW (10-28-2021) |
#3 | |
Drives: 2013 frs base
| The Following User Says Thank You to blsfrs For This Useful Post: | TommyW (10-29-2021) |
#4 | |
| The Following User Says Thank You to TommyW For This Useful Post: | blsfrs (10-29-2021) |
Drives: Fr-s
The first splitter I made had a negative rake (~.75") by accident. When realized, I made a second one that was more appropriately angled at .5* up in the back. At road America I picked up a couple MPH (and a little better balance but different days so take that for what it's worth) down the front straight so it stands to reason that, with a negative rake, it wasn't as efficient as it could have been.
It is, however, nearly impossible to get out of my driveway with the splitter on.
| The Following User Says Thank You to redlined600 For This Useful Post: | TommyW (10-29-2021) |
#6 | |
Drives: Crapcan
I had an off and the rear of my splitter came loose and it was angled up a few degrees. Car handled like shit after that. Getting it flat, or tilted down a bit helps a lot.
#7 | |
Attachment 206787
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | NoHaveMSG (11-14-2021), treedodger (11-14-2021) |
#8 | |
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | blsfrs (11-14-2021) |
| whiteline front endlink adjustment | oppiee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-20-2018 12:23 AM |
| Apr front splitter front bumper fitment | KungFuWaffle | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 03-03-2017 11:41 AM |
| Just Added APR front splitter and side splitter | Pekingduck | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 08-31-2016 10:22 AM |
| Front camber adjustment. | solidONE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 75 | 10-01-2015 03:32 AM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
