Old 10-26-2021, 11:41 PM   #1
mkootayy
Drives: 2013 subaru brz black
Question Stock tune needed for BRZ & State Ref
My '13 BRZ has a state ref against it and the OFT v2 I have doesnt have the stock tune. I'm trying to remap it to something thatll pass emissions tests, currently running stage 1 and expect to return car to stock to sell. Heard I may need a new ECU or third party shops say I can find a solution that isnt 100% guaranteed for half the cost of the ecu but still may need one. Car passes smog, not state ref emissions tests.
Looking for stock tune file/map, an ecu thatll get me through the inspection, do not know what to do, any help is appreciated.
mkootayy is offline   Reply With Quote
Old 10-27-2021, 02:34 AM   #2
steve99
what is the ecu calid you need ??
a 2013 manual usa canada can come with ZA1JA00C A01C B00c or B01C
auto ZA1JA00D A01D B00D or B01D
I have posted a lot of stock tunes here on my tactrix thread
https://www.ft86club.com/forums/showthread.php?t=62332
If its not there tell me which one you need
worst case buy a tactrix www.tactrix.com and you can flash the calid you need
Old 10-28-2021, 06:16 PM   #3
mkootayy
Thumbs up
CALID ZA1JA01G
downloaded xml file from your post, thank you very helpful. Heard a lot of great things of you steve appreciate your help, good man! At the moment I'm trying to reflash the ecu with the file but I run into many walls as I'm not familiar with the processes. I am using OpenFlash Manager to try to upload the stock tune to the OFT v2 Tablet, getting error when Uploading Data saying file size is incorrect. Maybe the .ori is the right file needed??
Old 10-29-2021, 08:11 AM   #4
steve99
CALID ZA1JA01G
downloaded xml file from your post, thank you very helpful. Heard a lot of great things of you steve appreciate your help, good man! At the moment I'm trying to reflash the ecu with the file but I run into many walls as I'm not familiar with the processes. I am using OpenFlash Manager to try to upload the stock tune to the OFT v2 Tablet, getting error when Uploading Data seaying file size is incorrect. Maybe the .ori is the right file needed??
Allthe rom files are same size 1.2 Mbytes tune files are .bin files
xnl files are definitions for romraider
you need a .bin tune file
If your car is USA car it wont be A01G calibration thats a substiture rom oft uses
also you cannot manually load files into the original slot on oft that can only be read from ecu
you can however load a stock tune into one of hte five tune slots and flash from there
what year is car assume its manual
Usa manual will ve B01C or B00C in most cases but sometimes A00C or A01C
post up an oftvtune that loads to oft here and ill have a look
Old 11-01-2021, 09:07 PM   #5
mkootayy
Red face
the car took the .hex file, i cannot seem to locate the stock tune in .bin, trying to get engine diagnostics from a drive to upload for review. the car is a 2013 subaru brz manual, using ZA1JB01C file at the moment. taking to subaru dealership for repair if they can do anything, then setting another california state smog referee and hopefully will pass, i see no reason it wouldnt. apologies for long time across responses, thanks once again!
Old 11-02-2021, 12:14 AM   #6
steve99
hex or bin is same ie if its ZA1JB01C.BIN or.hex it same so all ok
Old 11-04-2021, 12:03 AM   #7
mkootayy
Uploaded B01C.hex to OFM and it says "Selected file is not compliant" current tune on the car is A01C.ori while the car runs well, has a cold start that fires up to about 1900 rpm, idles ~1300rpm and sometimes pops during downshift, I'm looking to install stock catback leave oem headers. I've schedule an appointment with Subaru for a reflash because it seems the car will pass state referee
Old 11-04-2021, 05:17 AM   #8
steve99
Ok you eill need to load a slghtly older ZA1JA01C stock rom
Old 11-04-2021, 05:22 AM   #9
steve99
See my post here
it has stock ZA1JA01C rom download that unzip and upload to oft and flash
https://www.ft86club.com/forums/show...84&postcount=2
Old 11-04-2021, 05:35 AM   #10
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
The lack of a written OFT user manual that should come wiht the tablet is really showing here.
Here is the link to the ROM you need from Steve.
ZA1JA01C_2013 USDM .zip
PetrolioBenzina is offline   Reply With Quote
Old 02-20-2022, 04:14 PM   #11
Wingnutt
Drives: Pearl White 2014
I am trying to do this as well and am also getting the not compliant error with both ZA1JA01C_2013 USDM BRZ.hex and ZA1JB01C.hex
Wingnutt is offline   Reply With Quote
Old 02-21-2022, 05:33 AM   #12
steve99
what ecu calid does oft say your car is ?
also download the original file from oft and post it here it may not be a stock file
ecu, emissions, state ref, stock tune
Engine Tune Needed for Track Day? Faulkner Engine, Exhaust, Transmission 21 11-21-2018 06:08 PM
Is a tune needed for a new exhaust?! Molina30 Engine, Exhaust, Transmission 9 12-05-2016 07:31 PM
Unichip tune software needed almeshtaq Software Tuning 0 06-24-2016 01:58 AM
OFT300 (Vortech/OFT) help needed (tune issue) sirsol66 Software Tuning 7 12-09-2015 12:17 PM
high octane fuel + FI, tune not needed? BRZPDX Forced Induction 6 09-30-2014 12:41 AM
