Old 10-21-2021, 02:48 PM   #1
Ghosttothepost
Drives: Graphite grey 2017 86
Exclamation No audio at all
Hello all. I recently purchased a 2017 86 from a salvage lot and rebuilt it. I plan on holding onto it for a long time and making some memories.
First hurdle seems to be that during a joy ride I turned up the bass and volume to enjoy my music when suddenly the audio cut out. Now there's no audio what so ever not even the beeps from the radio when you press the buttons and what not. Turning on the car off and on and the radio didn't seem to fix things.
Funny enough when I was typing this I just turned on my car and the radio/audio worked fine for a second before it went out again.
So Is this a speaker issue or the radio itself? Was planning on removing the radio to disconnect and reconnect everything to see if that will do the trick.
Ghosttothepost is offline   Reply With Quote
Old 10-21-2021, 02:53 PM   #2
Ghosttothepost
Another car restart and the radio works. Obviously I'm afraid of even turning the nob an inch up.
Edit: it seems that after messing with it some more that at a certain volume or I guess bass boom. The audio cuts out. And turning the car off and on again gets it back working. Also it seems bumpy roads seem to knock it back on and off so I'm chalking up to some kind of wiring. Just wondering if it's the speakers or radio
Old 10-21-2021, 03:30 PM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
First off, pull the head unit out of the dash and look at the wiring behind there. If you see any signs of "altering", I would say that someone has done a poor installation of some of the components in your car.
There's probably a speaker or speaker wire that is shorting to ground. Pop one of your dash speaker grills out and snap a picture of what you find in there then post it here. We'll go from there. It wouldn't hurt to snap a picture of and post what you find behind the head unit as well.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 10-22-2021, 01:49 AM   #4
humfrz
Tell me you checked the fuse to make sure it wasn't defective or lose?
Old 10-22-2021, 03:50 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
Doesn't hurt, but if the head unit is lighting up like it has power the whole time, it's more likely going to be either a fault in the head unit, or speaker wiring fault.
Important to check the wiring at this stage because if that's where the fault is, a replacement head unit is going to be a waste of money
humfrz (10-22-2021)
Old 10-31-2021, 02:27 PM   #6
Ghosttothepost
Welp, I popped the speakers and head unit out and took a peak, didnt fiddle or touch any wiring and put it back and viola somehow its magically fine now. Even after stress testing with the volume maxed and the Bass high. Really weird but, im not gonna go any further if its all fine at the moment. Still a weird random event cause it was fine for days before then only a couple of days it had that fuss and now since its been a week there's been no hiccups. I appreciate the replies and suggestions though.
The Following User Says Thank You to Ghosttothepost For This Useful Post:
humfrz (11-02-2021)
Old 11-02-2021, 11:15 PM   #7
humfrz
Yep, Bubba said it had a bad ground, fer sure.
Bad gas, bad dirt, bad ground - it had to be one of those three -
Old 11-03-2021, 12:11 AM   #8
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
I had alternator whine coming through my speakers due to a bad ground on the stock harness. Cut the wire, grounded to the frame behind radio, now it's gone. If you ever have another issue with the headunit I suggest changing the headunit to a dedicated ground.
Brz866 is offline   Reply With Quote
The Following User Says Thank You to Brz866 For This Useful Post:
humfrz (11-03-2021)
audio, problem, radio, speakers
New Audio System: OEM Audio+ Reference, Audison Prima 8.9, or Hertz Energy setup? gamjatang Electronics | Audio | NAV | Infotainment 10 12-04-2015 04:12 PM
Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! CamryDS Audio/Visual, Electronics, Infotainment, NAV 25 10-23-2015 09:10 AM
Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 slicktop Miscellaneous 1 07-11-2014 08:58 AM
WTB: berk dual delete/perrin exhaust. JDL El headers. BBK kit. OEM Audio+/JL Audio YEAHdams Want-To-Buy Requests 0 07-01-2014 11:37 AM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
