Old 10-17-2021, 04:29 PM   #1
shlr
Drives: 2017 Subaru BRZ
How to depin headunit harness pins?
I installed a aftermarket headunit and have been trying to move a pin from the 10pin connector to the 28pin connector. See here: https://imgur.com/nfHKi7j
My (simple) issue is trying to remove the pin from the connectors. Does anyone have a guide/know how to depin these connectors?
I have a few pin extractors for depinning but just putting it in the hole above the connectors does not do the trick.
These are the connectors I’m trying to depin: https://imgur.com/a/EW1yoKg
Thanks.
shlr is offline   Reply With Quote
Old 10-17-2021, 05:13 PM   #2
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
There's a crap-ton of various and sundry de-pinning tools and virtually none of them work with a different model connector.
https://www.amazon.com/Extractor-Dep.../dp/B0922GF9W8https://www.amazon.com/Extractor-Dep.../dp/B0922GF9W8
Old 10-17-2021, 05:25 PM   #3
shlr
That’s essentially what I have but, for the life of me, I can’t figure out how to get the pins out.
Old 10-17-2021, 06:49 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
well, the simpler answer is that you can't move anything from the 10-pin to the 28 pin because the pin styles are different sizes.
i also would never re-pin the vehicle-side harnesses. GET ADAPTER HARNESSES AND HACK THEM UP.
#triggered
re-pinning oem harnesses works great until you need to troubleshoot it after forgetting what you did all those years ago--how do you think i know this one?
and i know #fuck-the-next-guy™, but re-pinning oem harnesses almost entirely dooms the vehicle to an early death if you sell from being bored of it in 2 years, and they try to re-use those same harnesses in a different way, all the while, it starts popping fuses.
an electrician once taught me: don't ever leave a mess for the next guy to fix, because half the time, it means you'll be that next guy."
add-on adapter harnesses are less than $50. just get the harness.
fs: DIY 6pins to 8 pins harness fibber1200 Exterior Parts (Aero, Lighting, Etc.) 1 03-30-2020 12:06 PM
Adding radio harness pins lbroskee Electronics | Audio | NAV | Infotainment 0 04-08-2016 03:08 PM
BRZ Radio Breakout Harness and/or Pins and Sockets nquillen Electronics | Audio | NAV | Infotainment 4 06-22-2014 10:40 PM
Foglight Harness Pins for sale FRSHunter Hawaii 3 08-22-2013 12:29 AM
