Drives: 2015 Subaru BRZ WRB
Battery disconnected for several months now power locks don't work.
The car starts and runs.
The trunk pops. But the car does not lock/unlock. In the mean time while the battery was disconnected I did swap out my blown motor for one that isn't. Which fuse should I look for ? Or is there a ground that I may have missed ? |
ProCrastinationConsultant
i believe the door locks are part of the accessory circuit that's in the under-dash fuse panel above the pedal box.
if your radio and dome light are working, i believe the fuse should be good. i recall someone else having a similar issue, but i can't remember the right search terms to find it right now...
You may wish to check the battery in the FOB - ??
At first I thought it wasn't the battery in the fob because the trunk still popped.
I then had the battery replaced anyways. Now everything works like it is supposed to. So weird that it would pop the trunk but not unlock the car with a low life battery. |
#5 | |
| 2013 FRS wont start unless battery is disconnected first | KN0W | Electronics | Audio | NAV | Infotainment | 5 | 07-21-2021 09:44 AM |
| Battery could die in 2 months for not driving? | alone1i | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 04-29-2020 06:21 AM |
| 10 months old - battery dead this am. Auto off headlights? | Large | Issues | Warranty | Recalls / TSB | 10 | 05-28-2016 10:12 PM |
| Disconnected battery with tune, throttle response weakened. | azynneo | Software Tuning | 8 | 01-16-2016 06:57 AM |
| battery disconnected/reconnected -- runs like shtako | jonbonazza | Issues | Warranty | Recalls / TSB | 2 | 06-19-2013 10:56 AM |
