Old 10-15-2021, 06:33 PM   #1
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Battery disconnected for several months now power locks don't work.
The car starts and runs.
The trunk pops.
But the car does not lock/unlock.
In the mean time while the battery was disconnected I did swap out my blown motor for one that isn't.
Which fuse should I look for ? Or is there a ground that I may have missed ?
irax is offline   Reply With Quote
Old 10-16-2021, 11:25 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i believe the door locks are part of the accessory circuit that's in the under-dash fuse panel above the pedal box.
if your radio and dome light are working, i believe the fuse should be good.
i recall someone else having a similar issue, but i can't remember the right search terms to find it right now...
Old 10-16-2021, 02:50 PM   #3
You may wish to check the battery in the FOB - ??
Old 10-17-2021, 03:27 PM   #4
irax
irax's Avatar
At first I thought it wasn't the battery in the fob because the trunk still popped.
I then had the battery replaced anyways. Now everything works like it is supposed to.
So weird that it would pop the trunk but not unlock the car with a low life battery.
The Following 2 Users Say Thank You to irax For This Useful Post:
humfrz (10-17-2021), soundman98 (10-17-2021)
Old 10-17-2021, 04:11 PM   #5
The trunk monkey assists in opening the trunk -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
bcj (10-17-2021), irax (10-17-2021), jcw99 (10-27-2021), soundman98 (10-17-2021)
2013 FRS wont start unless battery is disconnected first KN0W Electronics | Audio | NAV | Infotainment 5 07-21-2021 09:44 AM
Battery could die in 2 months for not driving? alone1i Scion FR-S / Toyota 86 GT86 General Forum 14 04-29-2020 06:21 AM
10 months old - battery dead this am. Auto off headlights? Large Issues | Warranty | Recalls / TSB 10 05-28-2016 10:12 PM
Disconnected battery with tune, throttle response weakened. azynneo Software Tuning 8 01-16-2016 06:57 AM
battery disconnected/reconnected -- runs like shtako jonbonazza Issues | Warranty | Recalls / TSB 2 06-19-2013 10:56 AM
