Old 10-14-2021, 05:43 PM   #1
oBradyG
Drives: 2020 Subaru BRZ AT
Dealership scheduled warranty maintenance soon..
Should i flash back to the stock tune for a scheduled warranty maintenance oil change and an alignment? ive seen people say when u take it to a dealership for anything u should flash back to stock? its a new car btw with only 13000 miles on it
oBradyG is offline   Reply With Quote
Old 10-16-2021, 03:43 AM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
I didn’t. I’ve got a 2019.
Drifter X is offline   Reply With Quote
Old 10-25-2021, 07:58 PM   #3
Grady
Grady's Avatar
No, Scheduled maintenance is still covered. By tuning you just do not have an warranty on your drivetrain anymore.
Old 10-25-2021, 09:36 PM   #4
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Actually it does nothing to your warranty. Thanks to Magnuson-Moss they have to prove that the modification/tune was the cause of the damage.
In my case, being at over 5000 feet above sea level, my car with a header and tune still has less horsepower than what the car has at sea level. So if I ever do have a problem I'd love to see them try and prove that my header/tune was the root cause
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 10-25-2021, 11:20 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
your technically right. but there's been plenty of cases where the only way to get to that technicality is with a jury...
Old 10-26-2021, 10:35 AM   #6
Grady
Grady's Avatar
A bad tune even with less HP will blow an engine. If you blow your engine and they know you have tuned the ECU they will deny the warranty. Have fun in court!
Old 10-26-2021, 03:06 PM   #7
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
The concern is that if they flashed the ecu for some reason it will screw you up. So two ways to protect yourself.
1. Flash back to stock
2. Tell them not to touch the ecu other than a reset. This is basically telling them you tuned it. For my cars I am out of warranty, so it does not matter.
Ernest72 is offline   Reply With Quote
Old 11-05-2021, 12:22 AM   #8
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Less power due to altitude, not because of the tune silly. Meanwhile starting this Oregonian sweat a bit with Gavin, Kate and Jay being so close and all in their implementation of Gavin's bullshit.
jeepmor is offline   Reply With Quote
The Following User Says Thank You to jeepmor For This Useful Post:
Jdmjunkie (11-05-2021)
Old 11-10-2021, 02:50 AM   #9
tomm.brz
Drives: brz 2017 hksv2
dealers can only upgrade available newer rom
99.9% your car doean t have an available upgrade so they won t flash anything
they can t even reflash the same tune and that s why they just swap ditectly with a new expensive ecu if they think the problem is in the ecu
in the case there is a newer rom for your car and they flash it with techstream/SMIII, if OFT then it will override your tune and brick your OFT, if Ecutek they won t be able to flash due to ecu lock
Old 11-10-2021, 05:34 AM   #10
steve99
Correct ecutek or brzedit tuned cars dealer canooth flash they would jist swap ECU
OFT or tactrix they can flash neither system will care. OFT only checks calid of tuned loaded to oft via openflash manager. Then it check vin of car, it doesnt actually check calid of tune in car , so it wont effect oft if dealer flashes new calid, but oft will jist overwrite with old calid next time you flash with oft
Old 12-24-2021, 04:40 PM   #11
callisto
Drives: 2019 Subaru BRZ
When dealers upgrade to a newer ROM, do they go a full letter up from e.g. S10C to V00C, or can they only go from S10C to S11C?
callisto is offline   Reply With Quote
Old 12-29-2021, 10:00 PM   #12
It would be very easy for them to.
You took the car out of its intended parameters of operation. A non-factory tune is a 100% guarantee that they can deny warranty coverage.
Old 12-30-2021, 03:33 PM   #13
bucketfoot
bucketfoot's Avatar
Only if they can directly connect it as a root cause of the issue.
Dealership wants maintenance in my 51km BRZ TMXSTAR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 12-05-2016 12:27 PM
Scheduled maintenance in San Diego trailofdead Southern California 7 05-24-2015 07:18 PM
subaru scheduled maintenance mike the snake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 11-28-2014 07:23 PM
Complimentary maintenance + tuned ECU, will the dealership know and void my warranty? retrosmiths Issues | Warranty | Recalls / TSB 4 08-07-2013 08:27 PM
Best Dealer for Free Scheduled Maintenance in SOCAL Area? nyanpire Southern California 6 08-09-2012 09:40 PM
