Old 10-13-2021, 01:14 PM   #1
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I need a rundown version of suspension mods.
I feel there's a lot more info than I can possibly digest, especially since all I want is a slightly lowered vehicle, with a setup that can feel as OEM+, meaning, improve a DD. So I have a few questions.
1) Whats is difference between coilovers against say, a set of Springs with Shocks.
2) What's the difference of price between coilovers? For example, I see TEINs for $1100 versus $1500+, does this mean the expensive ones are better, or are they rated for more competition setups.
3) I plan on switching to Michellin AS-4, so what would be the recommended suspension settings?
4) As an introduction to suspension mods, what would be considered a good amount of money to spend, kind of tied to question 2.
5) Did Epstein really off himself?
I do not mean to insult anyone's knowledge, is just that suspension is very new to me, as a lot of you know, this is my very first sports vehicle and the very first vehicle that I have been able to start learning about modifications. I also like to ask a lot of questions. Thanks in advance.
The Following User Says Thank You to spcmafia For This Useful Post:
soundman98 (08-09-2022)
Old 10-13-2021, 01:40 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Answered question within the quoted section below:
Height adjustability is the main one. Packaging is generally smaller with aftermarket coilovers as well. Also, the springs and shocks on a aftermarket coilover are generally developed together to work with each other. Where as damper Y may not have the ideal damping rate for spring X if you're mixing and matching and it's not adjustable.
Prices can be from under $1k to the moon, depending on use case. Lower priced ones may just be height adjustable, then you get into single damping adjustability, 2-way adjustability, 3-way, external reservoir, etc. Typically the amount of adjustability and track-worthiness drives the price.
Totally depends on what you use the car for. For a daily driver, maybe do springs, stock dampers and call it done. For a track build you might go 2-way adjustable aftermarket coilovers so you can tune them at the track. This is entirely user dependent. You can always upgrade little by little and find a setup you like. Since you're going with an all season, I imagine you aren't too track focused, so a spring/shock or an entry level aftermarket coilover would probably be fine.
Similarly to 3, it is entirely dependent on what you want to do with the car.
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
soundman98 (08-09-2022), spcmafia (10-13-2021)
Old 10-13-2021, 01:55 PM   #3
spcmafia
spcmafia's Avatar
Thanks!. The "depending on needs and use" comment is the one where I get a little confused on. Correct me if I am wrong.
Say I just want to keep the BRZ for daily driving/ spirited run, with All Seasons, best would be lowered springs with either OEM shocks, or something like the Yellow RCE with Blinstein combo.
On that note, TEIN CSG Spec would be also considered entry-level?
My goal is to reduce the wheel gap, by an inch, while slightly improving the performance compared to OEM. So basically entry level. I am completely open to tracking, but is not my focus, I understand that you can track/Auto-X with an OEM vehicle and still have fun.
Old 10-13-2021, 02:18 PM   #4
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
I had those same use cases as you, and went with the RCE Yellows/Bilstein setup and could not be happier. Honestly the dampers are probably overkill for most street driving but the car feels SO planted now.
I come from tracking motorcycles, where I had a zillion different adjustments I could make, front and rear. For me, adjustability for a street car is just more stuff I don't need to fiddle with.
Cephas is offline   Reply With Quote
The Following 5 Users Say Thank You to Cephas For This Useful Post:
Capt Spaulding (10-13-2021), Racecomp Engineering (10-13-2021), spcmafia (10-13-2021), Thefalls (10-14-2021), tobin (07-01-2022)
Old 10-13-2021, 02:23 PM   #5
BigTuna
BigTuna's Avatar
You are correct. What I mean when I refer to "use case" is what kind of usage the car will see. Those include daily driver, weekend-only toy, canyon carving, autoX, track days, time attack, or a mixture of any of them. Based on these, you can tailor a setup that will work best.
If you don't want or need height adjustability, then go with springs and either stock or aftermarket dampers. You can even get adjustable dampers if that's something you want to be able to play with.
If you want height adjustability and damper adjustability, go with aftermarket coilovers that offer such. Tein is a good brand. I've had the FlexZ which were fine for daily driving and AutoX, Fortune Auto 500's are good as well, Basically in the $1-1.5k range is the going rate for a good set of daily capable aftermarket coilovers. Single adjustability is being able to adjust one characteristic of the shock (typically rebound). 2-way let you adjust rebound and compression.
The Following User Says Thank You to BigTuna For This Useful Post:
Old 10-13-2021, 03:01 PM   #6
spcmafia
spcmafia's Avatar
Right now I'm looking into either the RCE Yellow combo, RCE Superstreets-1, and TEIN FLEX-A CSG Spec, slightly similar in price. They all seem to have what I'm looking for.
Old 10-13-2021, 03:23 PM   #7
https://www.instagram.com/p/CLEl6v5n..._web_copy_link
Not 86/BRZ specific, but a general overview. For this car, lowering more than an inch on just springs is when you start really feeling the lack of travel.
https://www.instagram.com/p/B7qn-gnn..._web_copy_link
Some more background here on different coilover features.
Really expensive coilovers can be awesome, but are generally designed for motorsports. They sometimes also require more frequent rebuilds or maintenance. Really cheap coilovers usually have poor quality damping or just aren't as well thought out. The reeeeeeally cheap stuff don't have the best build quality. Lots of sub $1k coilovers use the same damper part for different cars (i.e. 350z using same shock as WRX or BRZ etc). Factory dampers are better than those in some coilovers.
With an all-season tire, you don't need anything too stiff and you don't need tons of camber. Exact specs should depend on whatever you end up with.
You don't have to spend a ton of money for an all-around fun fast easy to live with suspension for an 86/BRZ. The 3 you've narrowed it down to are good options.
https://www.instagram.com/p/CFzNtLPH..._web_copy_link
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Cephas (10-19-2021), soundman98 (08-09-2022), spcmafia (10-13-2021)
Old 10-13-2021, 03:56 PM   #8
spcmafia
spcmafia's Avatar
- Andrew
Amazing info! Thanks a lot! I’ll be getting in touch soon!
Old 05-12-2022, 10:01 AM   #9
spcmafia
spcmafia's Avatar
- Andrew
Reviving this thread as I am getting ready to upgrade suspension. I'm having a hard time deciding between your RCE Yellows/Bilstein Combo or RCE SuperStreet-1. Budget wise, the combo would make more sense. But I'm also thinking in the long-run when I track, if having the SS-1 would be better suited for track/street uses.
Tracking is a bit far, so the car sees mostly highway and back roads. I think a 20mm drop is more than enough as I wouldn't go any further than 1 inch drop, also so that @NoHaveMSG stops making fun of my wheel gap.
Are there settings I would have to change/set with the SS-1s or does it come with a standard setup from factory. Also, do you recommend getting the shock mounts, mine are fairly new (2018) I only have 34K miles. Thanks!
Forgot to mention, I did end up getting AS-4 Michelin Tires, slightly bigger than OEM 225/45R17, I'm assuming getting either suspension wouldn't necessarily need much adjustment.
NoHaveMSG (05-12-2022)
Old 05-12-2022, 11:22 AM   #10
In terms of settings, we have some good guidelines for the coilovers on how to set height, alignment, damping, etc. You won't need to mess with them much once it's set. It's helpful to get an extra set of rear mounts just to make assembly easier (so you don't have to take apart your OEM stuff).
You're okay on tire fitment with either suspension.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
spcmafia (05-12-2022)
Old 05-12-2022, 11:26 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Both would be serviceable but considering your usage the Yellow/Bilstein combo will be more practical and enjoyable when you are driving the car regularly.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (08-09-2022), spcmafia (05-12-2022)
Old 05-12-2022, 11:39 AM   #12
spcmafia
spcmafia's Avatar
As long as it reduces my wheel gap to your approval, I'll get it lol.
NoHaveMSG (05-13-2022)
Old 05-13-2022, 09:49 AM   #13
Cephas
Cephas's Avatar
I'm on RCE Yellows and Bilsteins and found the wheel gap improvement to be just about perfect.
Plus if I was any lower I couldn't get in my driveway, so...
Old 05-13-2022, 10:29 AM   #14
Bilstein B6 finally back in stock after almost 6 months or whatever.
(SS1 in stock too).
- Andrew
x808drifter (05-13-2022)
Suspension mods worth it? Coaster Other Vehicles & General Automotive Discussions 8 06-15-2021 03:42 AM
Recommendations for Suspension Mods Seth Hawkins Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-28-2015 12:20 PM
KW version 3 suspension SOCAL large pictures jdzumwalt Brakes, Suspension, Chassis 3 08-31-2014 02:51 PM
TRD Suspension Mods Strat AFRICA 0 07-28-2013 11:32 AM
FRS BRZ Suspension Mods phm14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-15-2012 10:25 AM
