Old 06-15-2012, 10:25 AM   #1
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
FRS BRZ Suspension Mods
I'm interested in lowering my FRS ~20mm, and dialing in a alignment that helps handling while staying street/tire friendly on a 95% street car running 235 40 17 streets. My MX-5 was set up with a fairy aggressive alignment that was great on track, but the toe out up front gave inside wear on the the street. The Ohlins COs were also very good, but the setup good be harsh on the rear bumpstops at times. As well as the 86 cars handle out of the box, it's going to be a challenge to add parts without detracting from the "compromise" factory setup. I haven't tracked the car yet, but the indications I've seen are that with the tires I intend to run, valving/rates/sways may be about good for me. I'm hoping to get the car lower and add a bit of camber without messing up the ride & handling qualities the car has now. Looking at some of the factory alignment settings posted here, I'm almost tempted to get my alignment checked/adjusted for a better baseline. Those of us who plan to run the stock dampers for a while need to know if there are valving differences between the FRS & BRZ. I have a FRS, and valving could possibly make for different rate selection. Costs for spring/plate kits will also have to be compared to the coilover option. Any seen stock crossweights with driver posted up? Suggestions on alignment specs and hardware needs to get where I need to be are greatly appreciated.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Best Mods for the BRZ TheShiftingChef Engine, Exhaust, Transmission 34 09-08-2012 11:01 PM
Possible Mods Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 8 01-17-2012 01:05 PM
Mods? Bruninho8 Scion FR-S / Toyota 86 GT86 General Forum 3 12-06-2011 06:11 PM
