Old 10-05-2021, 11:42 AM   #1
Limitz
Drives: Black Scion FR-S
Wheel fitment help
Hello, I recently got some rims size 18x9.5 with an offset of +35 and they were too wide that they’d hit the spring. There is very little clearance, maybe even no clearance, I couldn’t really mount the tires so it was hard to tell. My question is what’s the best size and offset for a good 18inch rim fitment ? I’m on stock suspension btw I don’t really mind a poke on the front , as long as there is no rubbing. I’m currently seeing if I can return the wheels and get new ones
Limitz is offline   Reply With Quote
Old 10-05-2021, 03:24 PM   #2
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
It depends on what tire size you want to run as well.
225/40/18 or 245/35/18 on a 18x8 ET35 would give the same suspension clearance as the stock 17" setup and be flush or stick out slightly. You could certainly go with an ET40 offset (12mm of clearance) and possibly ET45, but that one would be getting tighter at 7mm of clearance. I have no idea how tight of clearances people run on these.
If I was running 18" one of the ET35 options are what I would likely opt for. I am running ET35 but on 17" wheels.
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 10-05-2021, 03:54 PM   #3
Limitz
Do you by any chance know if my problem was the width ? Since I got it 9.5? I went to the tire shop to get a second opinion and they told me that I should of gone with an offset of +12 which is why I’m more confused than ever lol
Old 10-05-2021, 04:45 PM   #4
bucketfoot
bucketfoot's Avatar
Yes, with that width you would need more offset (or less depending on how you look at it).
I'm still new to these cars, but dealt with offset planning quite a bit on my previous car, but it looks to me like you would want around +25mm of offset to have clearance with some extra margin (8mm). Technically 30mm would still have 3mm of clearance, but as I said before I don't know how tight you can safely run this on these cars.
But running these you would end up with some definite poke on the tires. So if you are good with that you could always go with a 10mm wheel spacer. But again I am not familiar enough with these cars yet to say how that would work out.
Old 10-05-2021, 04:47 PM   #5
bucketfoot
bucketfoot's Avatar
It might be worth spending the small price for the Wheel-it-Fit tool (https://wheel-it-fit.com/).
Old 10-05-2021, 04:50 PM   #6
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
I believe the wheels you bought would fit with coilovers…
ACT86 is offline   Reply With Quote
Old 10-05-2021, 05:09 PM   #7
Limitz
Well I’m now going to sell my new rims try to make the cash back and go less wide I’m being told 18x8.0-8.5 with offset 38 would be good
Old 10-05-2021, 05:37 PM   #8
whataboutbob
AutoX-10/10ths every run
I'd look at this first before you buy another set: https://www.ft86club.com/forums/showthread.php?t=7535
Build thread:Here
Old 10-05-2021, 06:00 PM   #9
bucketfoot
bucketfoot's Avatar
Either of those would definitely work, but again I'm no expert on these cars and there may be ways to make the existing ones work.
I would certainly check out the thread that whataboutbob posted.
Old 10-05-2021, 09:54 PM   #10
ACT86
ACT86's Avatar
8.5x38 would be fine
If you didn’t want poke at the front, can confirm 8.5 ET44 clears stock struts with 255/35s.
Wheel Fitment Icarus808 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-20-2020 05:46 PM
Wheel fitment help FrsBoyz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-20-2016 12:37 PM
Help with wheel fitment jplake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-31-2016 08:08 AM
Wheel fitment help. sskillzz12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-28-2015 12:49 PM
Wheel fitment odessitik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-30-2014 08:39 PM
