Old 10-02-2021, 12:41 AM   #1
Kitch86
Kitch86's Avatar
Drives: 13 widebody gt86
Need some Info on buying a motor
I need to buy a motor but so far everywhere is outrageous I have a 13 frs any help would be greatly appreciated
Kitch86 is offline   Reply With Quote
Old 10-02-2021, 01:08 AM   #2
Ashikabi
Ashikabi's Avatar
Average price seems to be about 3500 used
Old 10-02-2021, 08:01 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
And at that price point I'd just buy a built stage 1 short block from IAG
Old 10-02-2021, 08:53 AM   #4
Ashikabi
Ashikabi's Avatar
But then you still have to assemble the rest of the engine. If you've got the skills and tools to do that, then do that.
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
DarkPira7e (10-02-2021), soundman98 (10-02-2021)
Old 10-02-2021, 12:40 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Yes, I want to caution that buying a built shortblock is very much a headache if you're not being supported by an experienced Subaru engine builder. There are a lot of little things (oil passage filters in the heads, for example, that would be easy to miss) that if forgotten or not replaced, will recirculate the debris they have caught into your NEW engine.
Built shortblocks are also missing several things that you may need from your existing engine that cannot be re-used ( like your front cover), your cam gears that SHOULD be re-purchased, since they have a lot of oil passages with tight clearances that hold oil ( and debris, as a result).
The front cover is like $400 on its own. New OCVs are expensive. Cam gears are about $300 a piece. heads needs to be dissembled and cleaned thoroughly. May as well get new valve seals. Uh oh, valve clearances aren't great, we need to measure and buy the right shims.
Oh, all new timing components.
Oh, new gasket set. New DI seals.
Uh oh, we have a misfire on 2 cylinders- let's take it apart. Yeah, we goofed the DI installations and need to replace the seals, so you'll be paying for another set and the specialty tool to replace the seals. Oh, it happened again on DI 4.
Can you see why a built block isn't fun? Ask me how I know, I just went through all of this (I didn't rip my DI seals, but I thought for damn sure I would've). I could go on and on. Get a low mileage longblock assembly, you'll be happier. Just try to source it yourself. otherwise you will get a rotten junkyard motor with " unknown" mileage from the salt belt that has been rusting for the past 3 years in a pick n' pull.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 02:39 PM
Toyota V6 & V8 motor swap info GTV86 Engine Swaps 54 08-12-2014 01:03 PM
Anybody else thinking about buying crawfords rebuilt motor and turbo? Frsexxxy Forced Induction 21 05-29-2013 04:07 AM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
