Drives: FRS
Data Logging and U codes
Today ran a data logger in the FRS at an AutoX and at the last run got a U0155 code and it put the car into limp mode (made the run really slow). I found this other thread with the same issue:
https://www.ft86club.com/forums/show...t=18511&page=2 Question is does anyone know of a fix, different hardware combination that doesn't do this or is it going to be a matter of unplugging the OBD connector before every run / track session? Running the OBDLink LX connector with Track Addict app. |
For autox I leave my car running, track days unplug and replug.
Drives: 2013 Scion FRS
Are additional lights coming up on the dash? I've recently come across this issue and I'm fairly certain it has to do with plugging things into the OBD2 port. I recently purchased a 2018 BRZ with a fairly loose OBD2 connector and if I jiggle the scan tool plug too much while it's in the port it trips several codes (including U0155) and turns on several lights on the dash. Exact thing happened with a friend's 2013 FR-S.
On my previous 2013 FR-S the port was very solid and I never had an issue. I don't have a solution yet unfortunately. Looking into getting an OBD2 extension so I don't have to constantly plug things in to actual port. I'm not sure if the next step would to just rewire a new plug. |
Drives: FRS
I did get other lights as well, ABS for sure of what I can remember. Getting an OBD extension in order to not plug into the actual port is a good idea.
| Aim Solo 2 DL vs OFT data logging? | deca | Tracking / Autocross / HPDE / Drifting | 6 | 02-22-2021 01:31 PM |
| Data logging with OFT question | ChrisBRZ13 | Software Tuning | 1 | 05-29-2019 04:25 PM |
| Data Logging Knock | Rederick | Software Tuning | 0 | 01-13-2018 05:24 PM |
| best data logging options | canadaRS1.0 | Software Tuning | 2 | 04-21-2015 05:25 PM |
| Cannot Read Data Logging From OFT | yoonjin | Software Tuning | 15 | 12-09-2014 06:53 PM |
