Old 09-21-2021, 06:00 PM   #1
Swhelan2000
Drives: 2012 supercharged brz
Limp mode.. where to start
Hey all, have a supercharged brz. Was sitting up for a couple months now after a battery charge and service it's in limp mode. Running an ecutek ECU and custom map. Flashed the codes and nothing that would cause limp mode. No dash lights.
Any ideas where to start?
Swhelan2000 is offline   Reply With Quote
Old 09-21-2021, 07:04 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
try to clear the codes and drive normally and see if it's ok f
Old 09-22-2021, 08:01 AM   #3
Swhelan2000
Cleared them but the same code persists for the AC unit
Old 09-22-2021, 08:40 AM   #4
Grady
Grady's Avatar
Did you accidentally put in Valet mode?
Old 09-27-2021, 05:51 PM   #5
Swhelan2000
I've tried the 4 maps that are installed on the car. Not sure if there is a valet mode or how to put it in/get it out
Old 09-28-2021, 08:06 AM   #6
Grady
Grady's Avatar
Map 4 is usually set up as Valet. Manual cars use the cruse control to select different maps. Are you manual and pulling back on it and switching through using the RPM?
Old 09-30-2021, 04:48 AM   #7
Swhelan2000
Yes exactly that mate. Wasn't sure if there was a separate thing for valet mode but all maps are the same
How to Fix Limp Mode? MidnightFumes Issues | Warranty | Recalls / TSB 7 01-20-2021 05:18 PM
Limp mode at 2K rpm NEED HELP!! Arthur_frs Engine, Exhaust, Transmission 5 04-13-2020 10:22 PM
Limp mode GTBOY Issues | Warranty | Recalls / TSB 4 06-07-2018 12:58 PM
Valet mode / limp mode? radroach Software Tuning 1 09-18-2017 11:34 AM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 03:35 AM
