Drives: 2013 frs base
Direct injector install question
How much force is required? I've had them in the freezer. Put a little oil in the tube and on the injector tip. I've pushed reasonably hard with finger pressure. The injectors were professionally serviced with new seals installed. Any thoughts?
Drives: 2016 scion frs
That sounds about the same force as i did. But hey im the one who has his engine running lean.
Hopefully others who have installed these can chime in. |
For better or worse, they're in. 2 made the "potato gun" sound and the other 2 slowly sled in as I tightened to rail bolts. There wasn't much resistance. I guess there is no way of knowing if things are good until I crank it up tomorrow. Thanks again.
I guess it worked
Initial fire up went well. Had a friend over to check for leaks while I held rpms at 2500. No leaks nor unusual noises. Had a p0198 cel. Guess who didn't have a sensor plugged in until it clicked. I need to learn how to datalog to make sure everything is ok.
| Direct injector mark 3 | sid94 | Want-To-Buy Requests | 0 | 05-19-2018 02:50 PM |
| Noobie injector install question | DAN_BRZ | Engine, Exhaust, Transmission | 0 | 04-15-2015 11:36 AM |
| Fuel injector install question | nlowell | Engine, Exhaust, Transmission | 1 | 03-21-2015 11:12 PM |
