View Poll Results: Tein Flex Z or Oem 2017+ Dampers w/ RCE Yellow Springs
Tein Flex Z Coilover 3 33.33%
OEM 2017+ Dampers w/ RCE Yellow Springs 6 66.67%
Voters: 9. You may not vote on this poll
Old 09-11-2021, 04:30 PM   #1
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Tien Flex Z's VS OEM 2017+ dampers/RCE Yellows
I apologize in advance if this has been asked before but upon my google search only one thread popped up matching my question and I wanted to look for some fresh thoughts!
A little backstory:
I am quite happy with my OEM 2017+ limited trim dampers paired with RCE yellow springs. All four corners got replaced brand new @ 38k miles due to a clunking issue when turning the steering wheel which appears to be coming from the strut mount/hat. Both full strut assemblies in the front were replaced including the top hat, which fixed the clunking issue for about 2000 miles, however it has came back louder than ever before, and on both sides. I have no idea what went wrong in the installation since there should be no way brand new parts are wearing out so fast.
I've scheduled to have the dealer take a look again this week, but don't know what else they can do. So comes my question, going aftermarket coils is the only option I can think of to fix this once and for all, but since I don't want to spend a huge sum of money, I was wondering if Tien Flex Z's are a better suspension system when compared to 2017+ dampers on RCE yellow springs in terms of ride quality/stiffness and most importantly longevity. Do aftermarket coilovers like these generally require replacing sooner than factory systems?
I do not do any track days/autox. Just relatively aggressive street driving and mountain runs from time to time.
Thank you if you read through all this.
ItsReiko is offline   Reply With Quote
Old 09-11-2021, 11:34 PM   #2
strat61caster
strat61caster's Avatar
Aftermarket coilovers are designed to require more maintenance and not last as long because cheap and sporty, stick with oe or oe like dampers.
ineedyourdiddly
Old 09-12-2021, 06:36 AM   #3
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Since you already have the RCE yellow springs then its better to get some Bilstein B6 and I'm sure you will like that set up as it comes highly regarded.
Do a search and you will find only good reviews.
Thefalls is offline   Reply With Quote
The Following 2 Users Say Thank You to Thefalls For This Useful Post:
Dzmitry (09-14-2021), ZDan (09-16-2021)
Old 09-12-2021, 10:05 AM   #4
If you want longevity, a coilover designed to be lowered will last longer than a stock damper with springs being taken out of its intended operating stroke range.
OEM 2017 Dampers, RCE Yellows, Peddler Top Hats jflogerzi Brakes, Suspension, Chassis 9 07-12-2021 09:36 PM
Camber plate for Tien Flex Z GivoFrz86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-16-2021 01:32 AM
Bilstein B8+RCE Yellows vs Tien Flex A's jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 11-25-2020 06:04 PM
Tien Flex Z Squeak CatalystPLUR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 12-16-2016 09:15 PM
