Old 09-11-2021, 04:16 PM   #1
gt7877
Drives: turbo frs
Ej20x swap frs
Dear
I have project FRS
I had finished fab every thing and engine now ready
But I need help to connect ej20x ecu to FRS ecu
To start and run odometer
Thnx in advanced..
gt7877 is offline   Reply With Quote
Old 09-11-2021, 04:50 PM   #2
alphasaur
friendly
Drives: 17' 86
Why?
Seems like the ej20 will have the same issues as the FA20 with non of the perks (direct & port injection)
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 09-11-2021, 11:02 PM   #3
gt7877
Drives: turbo frs
Why!!
Because fa20 damage 2nd time because of bad oil pump ..
First time 47mil
5w30 oil
Here engine price much expansive
Ej20x can found full part at cheap price ..
Old 09-12-2021, 05:51 AM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
You will need a full standalone system most likely if you want everything to work.
All in your already probably at the cost of 2 more OEM motors.
Sorry to say its you or whoever is tuning/building your engines not the FA20 that's at fault here.
The Following User Says Thank You to x808drifter For This Useful Post:
alphasaur (09-12-2021)
Old 09-12-2021, 10:02 AM   #5
gt7877
Drives: turbo frs
Thnx bro
Fa20 used one cost Herr 2k
All fab and used ej20x my friend spent around 1300$
I told him better to use standalone ecu ..
Good thing not Alfred of bad oil pump
With good hp around 286hp stock motors
So now way to connect fa20 to ej20 ecu??
Thnx again
Old 09-12-2021, 12:11 PM   #6
PulsarBeeerz
Drives: JRSC BRZ SOLD
Custom harness and or standalone ECU.
PulsarBeeerz is offline   Reply With Quote
Old 09-12-2021, 01:09 PM   #7
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Just to throw it out there... If you had engine failure and reused your timing cover, you're doomed to repeat failure. The oil pump gets compacted fragments in it.
Nothing inherently wrong with an EJ20X swap, but it's going to be so much work for possibly nothing. I can't fathom how this would work without investing as much as any other engine swap.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
alphasaur (09-12-2021), gt7877 (09-16-2021)
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Nav swap Dadillac Electronics | Audio | NAV | Infotainment 4 10-21-2018 05:36 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
LQ4 V8 Swap nmctacticz Engine Swaps 42 05-02-2017 04:24 PM
