Old 10-20-2018, 03:57 PM   #1
Dadillac
Drives: 2018 Ford Mustang EB Premium 6M
Nav swap
Since our cars are twins and almost all parts are identical I have a question about electrical. I have a '19 86 without nav. Would really like to have nav. Will a nav unit from an FRS or BRZ work in the Toyota? Did Subaru/Scion/Toyota all have the same wiring? I would figure so but not sure. Does anyone know? Thanks
Don
Dadillac is offline   Reply With Quote
Old 10-20-2018, 04:15 PM   #2
Depending on your radio the NAV is an add-on option. basically its a piggyback unit that goes under the headunit. Does your radio have a "MAP" button on it, if so that is most likely the case.
I added the NAV module (purchased off eBay) to a 2014 Pioneer OEM radio (purchased from here from an owner that upgraded) and it all fit easily in my '13 with no wiring changes.
Old 10-21-2018, 11:38 AM   #3
Dadillac
No my head unit is not a nav capable unit. I was under the impression that the nav units are an all in one. As in the nav module is inside the nav head unit.
Don
The Following User Says Thank You to Dadillac For This Useful Post:
Dadhawk (10-21-2018)
Old 10-21-2018, 03:51 PM   #4
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
With regards to swapping around head units from previous model year FR-S/86s, unless Toyota changed the wiring around in the 2019 86, you shouldn't have much of a problem (perhaps maybe the back-up camera if going with a 2015 or earlier unit).
BRZs are slightly different from 2016 and up; the speaker wire is located on a different connector, so it wouldn't be a plug-and-play deal; you'd lose your door speakers otherwise. Otherwise, 2015 and older have identical wiring IIRC. I would do some research either way, as some members have complained about their Starlink units.
If you plan on getting a new head unit, why not look into the aftermarket? Do you wish to stay OEM?
Old 10-21-2018, 06:36 PM   #5
Dadillac
Not really interested in aftermarket units. Think I am gonna switch gears and find a slick phone mount and just use Google Maps. Thanks
Don
3UR-FE Swap BRX Engine Swaps 78 07-23-2021 01:49 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 03:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 08:59 PM
AT swap to MT CodyFRS Engine, Exhaust, Transmission 25 10-30-2013 11:39 PM
