Old 09-03-2021, 02:58 PM   #1
cadeb
Drives: black
Exclamation Need Battery Information ASAP
I was reinstalling the negative terminal clamp back onto the battery when the bolt snapped and the clamp went loose. Obviously I cannot drive anywhere like this and was wondering if anyone on here knows the part number or a viable replacement for the terminal. I know that we have a special clamp with some type of sensor next to the copper wire.
cadeb is offline   Reply With Quote
Old 09-03-2021, 03:31 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I think Bubba would suggest a bolt and nut combo that fits in the hole. Leave the connector be.
What do you think @?
Old 09-03-2021, 04:22 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Take broken pieces to Napa. Ask for comparable part, it may not be exact but it will be close enough. Likely standard and not metric.
Old 09-03-2021, 07:45 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Bubba would be right. And clean all of that corrosion off while you're in there. And why is that red wire cut?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 09-03-2021, 08:19 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
i lost my bolt like that a while back. it's a generic subaru bolt. the replacement i got was listed for an outback or something. talk to any of the auto parts stores. they'll have something that will work.
it's just a bolt with a fancy end on it, trick is to not tell the car you're using a different bolt, and it'll never know the difference!
Old 09-03-2021, 08:45 PM   #6
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
If you can't find the exact bolt I would think you can buy any terminal and just use the bolt from it
2020BRZtS is offline   Reply With Quote
Old 09-04-2021, 03:51 PM   #7
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Why do you think you cannot drive with a loose battery terminal? Clean it up, squeeze the ends of the terminal together slightly with a pair of pliers, and you will find it makes a nice, snug connection as you push it down on the terminal.
This is not a permanent fix and you should replace the bolt as suggested above by other responses
My point is there is no problem driving the car short distances without the bolt (like to the parts store and back). If the connection is loose the most likely "failure" is that you battery won't charge well and eventually you will not be able to restart and require a jump.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 09-04-2021, 10:02 PM   #8
Project_1796
Drives: Scion FRS 10 series
Here's the part #
23775AA060
Project_1796 is offline   Reply With Quote
Old 09-05-2021, 04:41 PM   #9
humfrz
Bubba thinks that would work. This would also work -
Old 09-05-2021, 08:24 PM   #10
soundman98
soundman98's Avatar
^that works in 3 ways.
it fastens down the battery clamp
it will keep you warm in the winter
and it will guarantee you'll need a new car!
Old 09-07-2021, 05:26 PM   #11
Sasquachulator
Pavement Grey
Its just gotta hold long enough for the second gens to come out!
Old 09-07-2021, 06:04 PM   #12
Funny, I would have never even thought about getting an "official" bolt. I would have dug through my collection of odd bolts, nuts and washers, found one that fit through the hole and moved on. I guess I have a little too much Bubba in me as well.
Old 09-07-2021, 07:04 PM   #13
Yoshoobaroo
TRACKBREAD
I think that’s just the right amount of Bubba. It’s a perfectly fine repair that won’t affect anything else.
Old 09-08-2021, 01:12 AM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
6 mm hex head cap screw, two washers, split lock washer, and nut.
Clamp the washers together, and file, sand, grind a flat on their sides deep enough to fit properly onto your terminal connector. If you're patient and handy enough, you can bend up the orthogonal sides of one of the washers to make a saddle for the screw head so it can't rotate while you tighten the nut.
battery, battery clamp, battery disconnect, battery repair
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 12:55 PM
Cheaper lighter battery option - Miata battery brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-06-2017 05:51 PM
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 12:07 AM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
