Drives: 2013 frs base
Functional aero mods
I'm thinking about adding a small front splitter (Devsport) which means I probably need to pair it with a smallish rear spoiler. I've already installed an underbody kit and fabricated a diffuser. My car is n/a, currently, with stock suspension. My goal is to improve aero without increasing drag.
Any suggestions on a spoiler? |
Drives: JRSC BRZ SOLD
Idk how functional the Devsport lip is as its not a full splitter at all. A rear spoiler isn't really needed to reduce drag, most won't. I'd consider both of them just cosmetic. The Verus ducktail has CFD data to validate any claims however, as does their splitter!
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | blsfrs (08-29-2021) |
Drives: Track preped NA FRS
Dont get too hung up on reducing drag to the point where you are sacrificing downforce. Up to a certain point, more downforce is always good, that point isnt a small splitter and little lip on the trunk.
| The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post: |
Are you just doing aero mods only for the sake of doing aero mods, or are you trying to achieve some sort of performance target/metric through only reducing drag? What's the end goal?
| The Following User Says Thank You to AFRichZC6 For This Useful Post: | blsfrs (09-05-2021) |
#5 | |
I am aiming for some drag reduction and maybe some increase in downforce. From what I have read, some mods can give you both. I realize that without wind tunnel or CFD testing there is no concrete way of knowing what combination of mods will make a change so I'm trying for an educated guess in a positive direction. |
#6 | |
It sounds like you should get OEM underbody panels next if your car didn’t come with them. |
| The Following 2 Users Say Thank You to norcalpb For This Useful Post: | blsfrs (09-05-2021), Yoshoobaroo (09-04-2021) |
#7 | ||
TRACKBREAD
Reducing lift and increasing downforce is the same thing. You’re reducing the net lift achieved by the aerodynamic body. There’s no such thing as downforce in aero calcs. Just lift, be it positive or negative. A car still behaves largely like a simple airfoil. Whichever side (top or bottom) has the faster air speed will have less static pressure. If the static pressure on top is smaller than the bottom you get positive lift, if not you get negative lift. Following that, generally, drag reduction under the car decreases lift, drag reduction on the top of the car (hood,roof,trunk) increases lift. That’s why spoilers decrease lift, they increase the drag on top of the car. Quote:
| The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post: |
#8 | |
Drives: 2017 toyota 86
The TRD aero stabilizer would be a good addition to pair. Don’t expect a crazy noticeable difference, but both should help on paper. Rear spats would be good to pair with that diffuser Extending the diffuser under the car further/ connecting it to flat under panels ideally it would be one smooth connected transition from front splitter to rear diffuser. Verus wheel deflectors would help Trd fender fins add downforce similar to canards but also redirects air around the mirrors so the drag penalty is reduced. Side skirts can reduce lift while reducing drag as well. You said you have underpanels already? Have pics? |
#9 | |
Attachment 204980Attachment 204980
I just got a used oem spoiler off of ebay. The underbody panels were my first aero mod. I do have panels between the floor and axles. A diffuser is ineffective without smooth air ahead of it. Getting the bottom of a car absolutely smooth is difficult and expensive but what I've got ain't too bad. I may fab up a removable diffuser extension. I didn't want it to extend too far out so I wouldn't nail my shins every time I went into the trunk. I'll look into your other suggestions. Thanks |
#10 |
Drives: Crapcan
Side splitters/skirts my be a good option for you. They prevent "mixing" and allow the underbody to work more efficiently. I'd also look at items like the little TRD fender garnishes that look like they help manage the airflow from the wheel wells.
Are you building for a class or building for funzies?
#11 |
Funzies. DE 2 for now. Thanks for the suggestions.
#12 | |
But here is my list of aero. Pretty good setup for a fun daily, everything functional, and also aesthetic in my opinion. The verus/jdm /speed factory combo underneath the car is effectively what you are after, without some custom fab work it’s about as smooth and flat underside as you can get, with the flat panels from front bumper to the rear diffuser all connected. Aero: Seibon FA Carbon Hood Greddy Gracer Front Lip Beatrush Undertray JDM Aero Underpanels OEM Rear Spoiler Verus Front Wheel Deflectors Verus Trans Tunnel Covers Verus Rear Aero Spats FT-86 Speedfactory Rear diff covers FT-86 Speedfactory Rear Diffuser TRD Front Fender Fins TRD Trunk Stabilizer cover TRD Aero Turbulator STI Side Skirts |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | blsfrs (09-06-2021) |
#13 |
I installed the Devsport splitter. I probably should have saved my time and money. It is composite aluminum and well made but, when it is bolted to the bottom of the bumper, it angles upward by a few degrees. This is not the aero effect that I was looking for. Devsport make some wedges but this will create a gap between the splitter and bumper that will need some sort of air dam. Over the winter I'll figure some out or scrap it all together.
#14 | |
This is what I use to fill on the bumper splitter gap. Can cut it to shape and it will squish a little to form. |
| The Following 3 Users Say Thank You to 86TOYO2k17 For This Useful Post: |
| Top 3 Aero Mods | thekevinvo | Cosmetic Modification (Interior/Exterior/Lighting) | 60 | 10-16-2020 04:02 PM |
| Turbo build plus aero mods | SpeedDemon26 | Want-To-Buy Requests | 1 | 02-07-2017 07:50 PM |
| Functional Aero Parts and their effects ? | glamcem | Tracking / Autocross / HPDE / Drifting | 185 | 09-19-2014 07:08 PM |
