Old 08-27-2021, 01:15 PM   #1
BradH_NC
Drives: 2013 FRS
Lock/Unlock Issues
The lock/unlock/trunk buttons inside the car and on the key fob do not work until I press them about 20 times, then they start working. The issue is getting slowly worse. There are no other electrical issues. Does anyone have the same issue, or has anyone resolved this issue?
BradH_NC is offline   Reply With Quote
The Following User Says Thank You to BradH_NC For This Useful Post:
humfrz (08-28-2021)
Old 08-27-2021, 03:27 PM   #2
norcalpb
norcalpb's Avatar
How do you the locks behave when you press the door button inside of the car?
Old 08-27-2021, 05:23 PM   #3
BradH_NC
Drives: 2013 FRS
In-car buttons (not key fob buttons) behave like this: The unlock button doesn't work until the car is warmed up. The lock button usually works. The trunk button doesn't work until the car is warmed up. There are no other electrical issues.
Old 08-27-2021, 08:07 PM   #4
norcalpb
norcalpb's Avatar
Does little red lock indicator wiggle when you press the buttons? It could be your door lock actuators which have gone bad on a lot of people’s twins. They get gunked up which may explain why it get worse over time and only work when the car is warmed up (warm gunk moves easier).
Old 08-28-2021, 06:38 PM   #5
humfrz
Captain Obvious here.
When opening the trunk, are you holding the fob button down for a couple of seconds?
Have you changed the fob battery?
Have you cleaned the contacts on the fob battery?
whataboutbob (08-29-2021)
Old 08-29-2021, 03:11 PM   #6
radroach
Drives: car
Have you tried your other set of keys? On my keys, one set of keys unlock on first press. But on my other set, I have to press 2-3 times. Not sure why.
Old 08-29-2021, 08:11 PM   #7
humfrz
Fer cryen out loud - what the hell have we done to ourselves -
Anyone else remember the simpler days. One key was for the doors and trunk, the other one was for the ignition! They were even shaped differently to give the driver a hint. For the truly challenged, there were only two keys per vehicle - if the one didn't fit - it must be the other one -
No bulky fob, no chips, no programming, no battery - just two fucking keys to unlock and start the car - SMH
(it must be past ma nap time - )
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Dzmitry (09-01-2021), norcalpb (08-29-2021), pope (08-31-2021), soundman98 (08-30-2021)
Old 08-30-2021, 03:20 PM   #8
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Dead (dying) battery in one...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Remote Lock/Unlock Issues STIMAN Issues | Warranty | Recalls / TSB 13 09-20-2021 07:01 PM
Trunk won't open and doors won't lock/unlock Mazikowski Electronics | Audio | NAV | Infotainment 13 03-05-2018 10:50 AM
Remote lock/unlock not working zdaughtry1 Electronics | Audio | NAV | Infotainment 2 03-16-2017 10:16 AM
Auto Lock and Convenient Unlock delusional DIY (Do-It-Yourself) Guides 4 11-07-2012 05:34 PM
