Old 08-25-2021, 02:02 AM   #1
Dazzo
Drives: 2013 FRS
Engine Knock, Vacuum Pump?
This is a 2013 FRS Automatic, 103k miles. My engine is currently making a tapping/knocking sound, the sound is not there when the car is cold; however, when warmed up the sound is heard. My biggest fear was engine knock but after browsing other forum posts I've seen that the automatic transmissions have an issue with vacuum pumps that sounds similar. I have attached videos of the sound below, it is primarily heard on the passenger side of the vehicle. What does this sound like? Engine Knock, Vacuum Pump, or other?
https://youtube.com/shorts/0xMiHdDV-PE?feature=share
https://youtube.com/shorts/T8iw4VxLs9A?feature=share
Dazzo is offline   Reply With Quote
Old 08-25-2021, 02:27 AM   #2
Boccaccio
CAD monkey
Boccaccio's Avatar
Drives: '15 GT86 Giallo - Supercharged
Sounds like a bad vacuum pump (+ you stating the sound is not present when cold):
Boccaccio is offline   Reply With Quote
engine, knock, noise, rod, vacuum pump
Engine Knock or Vacuum Pump? Dazzo Scion FR-S / Toyota 86 GT86 General Forum 2 08-26-2021 03:22 AM
Brief engine knock/cold engine/first couple accelerations@2.8-3krpm Reyanth Issues | Warranty | Recalls / TSB 5 11-15-2020 02:32 PM
DIY - Finding a vacuum leak (Cigar/Pump method) BigTuna DIY (Do-It-Yourself) Guides 0 08-12-2019 10:13 AM
Vacuum Pump? febrz Issues | Warranty | Recalls / TSB 0 04-13-2018 04:08 PM
Vacuum pump oil USMCgetsome Engine, Exhaust, Transmission 4 12-10-2016 08:16 AM
