Old 08-23-2021, 03:38 PM   #1
Dazzo
Drives: 2013 FRS
Engine Knock or Vacuum Pump?
This is a 2013 FRS Automatic, 103k miles. My engine is currently making a tapping/knocking sound, the sound is not there when the car is cold; however, when warmed up the sound is heard. My biggest fear was engine knock but after browsing other forum posts I've seen that the automatic transmissions have an issue with vacuum pumps that sounds similar. I have attached videos of the sound below, it is primarily heard on the passenger side of the vehicle. What does this sound like? Engine Knock, Vacuum Pump, or other?
Dazzo is offline   Reply With Quote
The Following User Says Thank You to Dazzo For This Useful Post:
humfrz (08-23-2021)
Old 08-23-2021, 04:19 PM   #2
humfrz
I can't tell anything from the videos.
I suggest get in closer to the vacuum pump and post a listen.
Old 08-26-2021, 03:22 AM   #3
OwlDance
Drives: Halo 86, '19
Sounds like some weird metallic clutter that happens either when you throttle too hard at low RPM or around the 4200 RPM mark. The deeper grunts sound like low RPM lugging to me.
OwlDance is offline   Reply With Quote
automatic, knock, noise, tap, vacuum pump
Brief engine knock/cold engine/first couple accelerations@2.8-3krpm Reyanth Issues | Warranty | Recalls / TSB 5 11-15-2020 02:32 PM
DIY - Finding a vacuum leak (Cigar/Pump method) BigTuna DIY (Do-It-Yourself) Guides 0 08-12-2019 10:13 AM
Vacuum Pump? febrz Issues | Warranty | Recalls / TSB 0 04-13-2018 04:08 PM
Engine knock Zentec Engine, Exhaust, Transmission 22 09-05-2017 03:46 PM
Vacuum pump oil USMCgetsome Engine, Exhaust, Transmission 4 12-10-2016 08:16 AM
